  • 3 weeks later...
On 5/22/2019 at 5:45 AM, JACKA87 said:
Awesome build mate, just read through it all. Great to see it being done with the goodies and a whole lot of patience!
cheers mate, the patience has worn thin a few times but I think it's all been worth it :)
So a little bit actually happened on this R&R trip home, not all good but not all bad...
I put her on club rego which significantly reduces the cost of registration and insurance here in SA (win, win)...
After a few minor but frustrating teething issues with injector plugs not actually being standard and dramas bleeding the ATTESSA she was finally turned over (boy had i missed that RB sound)...
She was then put on the dyno for a few hours to run her in and do some basic tuning on 98RON. Very happy with the results on pump fuel, just running wastegate pressure (12-13psi) ended up with 279rwkws from memory, video shows the run before at 275rwkws...
Initial feelings from these turbos is impressive, the response is very transient and feels better than what i recall my -7's did...
Whilst out and about putting a few kilometers on her i was thinking to myself she was feeling a little stiff, just put it down to me being a couple years older than when i last drove her but once i got out for the first time i noticed one side was sitting far lower than the other at the rear, after hopping underneath it appeared as though one shock had compressed and not rebounded, so I got her home and pulled the rears out and sure enough this was the case as seen in the below photo ? So now I weigh up whether to rebuild the rears as i did the fronts (really like the feeling the bilsteins give) or I look into some coilovers... The cars driveable so not a huge urgency...
I dropped her off last night before flying back out to site this morning so fingers crossed the 98 tune will be completed along with the E85 over the next 2 weeks... Very excited to see what some E85 in her guts will do :)
  • Like 3
11 hours ago, Dose Pipe Sutututu said:
Go MCA!!!
This was what I was going to do...
But the guy who I use for tuning and bits & bobs I can't do here in Adelaide said they'd had issues with MCA recently when there was warranty issues, has kinda put me off ?
I had just been reading up about 'The street Essentials' (shows how long it's been since i looked at suspension) they just used to do 'blue', 'red, and 'gold' haha...
2 hours ago, Dose Pipe Sutututu said:
Yeah they've increased their range to meet market needs, but I feel now they've done that the distinction between the lines are blurred.
yup, exactly what I was thinking whilst perusing their site this morning ??
They still get it so right though, I run MCA X-R (not sure what they're equivalent to now) with 10/7 spring rates and they feel less harsh than a set of BC BR 8/6
I don't mind the idea of the 'street essentials' in stealth black...
7 minutes ago, MBS206 said:
I'm a fan of blistein, and if they were well sorted and it drove nicely, why chance it?
finding someone who will rebuild them is the only thing stopping that from happening...
here in oz it appears everything these days is throw away and replace (boy i sound old saying that) ?
Edited by mr_rbman
  • Haha 1
Wasn't white line rebuilding them at least back in the day?
got an email back from Bilstein Australia themselves who actually appear to have bought Quadrant suspensions (in Victoria) so may have a solution, they are calling me back tomorrow.
  • Like 1
Just got word from the tuner it is currently making 323rwkws @16-17psi... on 98RON
Fuel pump appears to possibly be an issue (Walbro 460) getting very warm... Looking into it further now...
  • 3 weeks later...
Well I think I can say I pretty much achieved what I set out to more than 2 years back...
I've got myself a NisTune cable so will try and get some logging done on my next R&R to show the rather impressive response achieved (as they dyno graphs obviously don't show it) given I was set on staying low mount twins. I know I could've achieved so much more with a modern single but I do honestly feel far less disappointed than I had expected to...
Finally got round to fitting the correct boot badges as well...
  • Like 3
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
