Same here, Supercharge but Gold series across all our cars for availability, warranty, cost, configuration variations and performance life. If I can't get these then only Century.
Would love to run the Supercharge AGMs in the Nissans but they don't have the pencil posts and varied post positions available like the Gold series.
  • Like 1
2 hours ago, Dose Pipe Sutututu said:
Looking real nice!
I've moved away from Optima, they aren't of the same quality as they used to be!
I now run a SuperCharge battery (made for Stop/start applications and is an AGM battery - similar to an Optima), not to mention it's an Aussie brand with 3 year warranty.
https://www.supercharge.com.au/car-battery/supercharge-start-stop-car/?post_type=battery_type&p=173
All the in-laws' cars run their SuperCharge Gold range batteries, cheap and phenomenal warranty.
Cheers Johnny, shall look into it...
Cheers Benny
1 hour ago, Dose Pipe Sutututu said:
I bet you're excited!
Also I would recommend using some form of heat shielding OR wrap your dump/downpipe to prevent your O2 harness melting at the track.
when u say o2 are you referring to the wideband? same same...?!?
as that's just cable tied in that position now til we workout where it will enter the car...
excuse my dumbness, these are the sides of cars that I fail at...
Edited by mr_rbman
For the Wideband O2 sensor I just go through the existing egt floor bung and a Haltech O2 sensor wiring extension harness. Don't want to drill more holes in car than necessary.
  • Like 1
ye that was my initial thinking...
just so I wrap my head around this, both a narrow band and wide band sensor are essentially both just o2 sensors correct!?!
Yes
  • Thanks 1
33 minutes ago, BK said:
Wideband gives you an actual afr / lambda ratio, narrowband just signals whether it's richer or leaner than Lambda 1 / AFR 14.7:1.
Clear as now, cheers Ben
54 minutes ago, Dose Pipe Sutututu said:
Just delete the OEM narrowband junk, since you now have a modern ECU.
tis already gone, just the one wideband roughly 1000mm from turbo..
  • Like 1
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
