I'm looking to swap the race car over to LEDs external lighting, this is my understanding of the bulb types for a 32 GTR:
2x Low beam headlights H3C. Note, later cars apparently run H1
2x High Beam headlights H3
2x Front Indicators BA15s
2x Rear Indicators BA15s
2x Reversing Lights BA15s
4x Stop/Parkers BA15d
2x Rear Number plate T10
2x Front/Side Indicators T10
2x Front Parkers T10
The question is, any recommendations for good quality LEDs? There are billions on ebay but I suspect their quality....
Buying List
2x H3C
2x H3
6x BA15s
4x BA15d
6x T10
In terms of the headlights, how effective do they actually need to be at night? (ie is it a daytime vehicle and you just need headlights for regulation/show)
I decided against them as pretty much everything I read indicated a poor light pattern. When you look at a LED retrofit for a reflector housing, the problem is apparent. Much of the "bulb" has to be a solid heat sink.
A pity because I like the technology, but the best solution would seem to be a LED chip with a lens to control the light pattern.
Ive used lots of cheap T10s . The main issue with the cheap chinese variety is that they drive the LEDs quite hard which leads to failure sooner and more often. You can also expect to have more of them flicker very early on.
I now build my own lights from components, my favourite being 10w chips.
There are now quite a few phillips branded LED replacements for bulbs, more expensive obviously.
  • Like 1
thanks everyone for the quick responses. I think I might go with Philips globes in the hope they are a little better made, even at their prices it is pretty cheap compared to everything else on a GTR.
The headlights don't look so simple. Robzilla the ones you linked to a H4 which are hi+lo, whereas my car has H3C lo and H3 Hi beams. Is yours the same and you modified to suit?
I use the headlights:
* on targa stages as the regs say they have to be on (so brightness doesnt matter)
* if I drive the car at night (very rare) but they have to be OK
* for racing at night, in which case I want them as bright as possible.
So I figure I will buy 2 sets of H3 lights, run 1 pair on lo beam and both pairs on high beam....total current draw for at 40w each for 4 lights is still only 13 amps.
Looks like I'll just go with a mid priced ebay set and see how they go.....I did notice that most sellers are willing to back their product for a whole 1 month warranty which fills me with confidence.
Ill be very interested in the results. Robzilla - do you have any further testing on those lights?
One issue is the light pattern, for example and LED retrofit can appear brighter than a halogen if the light pattern concentrates the beam right in front of the vehicle, but once you're moving you'll find the light isn't projecting down the road where you need to see things.
To make matters worse, your eyes adjust to the pattern of the light, and the bright patch in front of the vehicle can reduce your sensitivity to whatever light is being projected further down the road.
Shall I chime in? Lol
If you have reflector (N1) headlights, anything other than halogen will be glare-y and the light pattern would be quite poor.
Read this: https://www.hidplanet.com/forums/forum/general-discussion/leds/64081-thoughts-on-h11-led-headlight-kit?p=1382874#post1382874
Things like foreground, hotspot near the cutoff, etc. are quite important for night driving (i.e. being able to see distance, not just in front of the bumper).
But since Duncan's car is a track car, glare doesn't really matter. Still, if you want to see at night...
Obviously the Philips are very good but expensive. I usually see that the eBay ones are very blue and die quicker. Don't expect the headlights ones to last that long (ones with a little fan on the back).
Or... I can sell you a pair of HID retrofitted projector headlights ;).
As for the rest, eBay ones should be fine.
i truly have never had an issue, i drive my car daily, like every day, i have never been flashed or blinded anyone, or anything, the original bulbs, even Phillips were horrible.
the LED placement is very deliberate to reflect of the reflector in a specific way, mounted one higher one lower, but yes its not going to be perfect, but as said i have never had an issue.
that being said, retrofitted HIDs, although pricey, win at life.
I've seen approximately 0 people flash someone with bad headlights. It's just an accepted thing on the road these days it seems.
Not saying your LED lamps are terrible, I've never seen them in real life, but generally running them isn't that great.
Granted the R32 projectors are shithouse (assuming reflectors are slightly better).
HID retrofit isn't that expensive, approximately $400-600 depending on how much you want to spend on bulbs and ballasts.
Got some output/wall shots GHO5T? Interested to see how they work with the R32 reflectors.
Duncan, do you want to see or be seen?
this is all i have,
this is before adjusting, i did adjust them down slightly as i usually do with brighter bulbs, but this is in comparison with the phillips white.
left light only phillips
right light only led
the phone is adjusting for the light difference obviously
but here is both left and right, old v new
on the road, this is th eN1 foglights vs the main beems on LED,
you can see the on comming traffic is not flooded by light
all i can say is i have had stock, phillips and i have also had HID in projectors, and i woudlnt go back from LED, not in these lamps anyway.
Edited by GH05T
Thanks for the pics. Clearly shows tons of foreground, glare and virtually no cut off (look at the trees and yellow bin + stuff behind it).
The halogens, although dimmer, does what it does (cutoff, no foreground).
But hey, as long as you're happy. City driving it would be fine (besides annoying other drivers lol), but good luck on country roads.
HID kit in standard projectors is a downgrade from halogen. All you get is two thin 'pillars' of useless glare-y pencil beams.
Here's a couple of crappy shots of Morimoto HID projectors (FX-R) behind the standard (streaky) R32 lenses.
Has too much foreground for my liking, will modify that at some stage (have to take everything apart again).
The output is diffused too much by the standard lens cover thingy. Next project is to retro another set with clear lenses from a UK company.
interesting input, thanks guys. I kind of feel like I posted should go twins or single turbo in the FI section.....
anyway, for street use I understand why the cutoff and foreground of LEDs are an issue and frankly it makes it an expensive gamble to get a good one....or perhaps there are no good ones....
in my case I was looking to make a current saving rather than getting a better than average bulb so it may still be OK to run a cheap LED globe. But clearly I am not going to get what I am after from an LED high beam so I think I might look into a light bar when (if) needed for night racing.
Also, between what I've read here, and the fact both headlights are a bit borken after years of racing, I've decided to replace both headlights with the base spec /N1 reflector lights which will take a much easier H4 bulb anyway.
And for the rest of the lights I've gone Philips from ebay.
Thank y'all
yeah its n1 lights, the cutoff is the same, the light output is different, thats all bulbs will give you.
projectors give you the cutoff.
But your road shots shows otherwise! Anyway...
Duncan, since you're going to throw N1 headlights in, look at some higher wattage lights? Or, the Narva 'blue plus' or whatever they're called these days work well (I bought a couple of pairs for family members' cars, they impressed me). Anything else are shit, including Philips 'style' ones.
Just be careful of ebay stuff, lots of fake Philips on there.
I got mine T10 and 30mm festoon from here (when they ran sales): http://www.powerbulbs.com/au/store/category/led-car-bulbs/all
4,000K Philips FTW.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
