Hi All
My name is Ed. I am new to Skyline ownership. I have been looking over this forum the past 4-6 months before buying a car, its a great source of information so thanks to everyone. I ended up getting a series 2 r33 gtst. I'm loving it so far but have one nagging issue...flat spots on boost.
I have been researching forums on the issue I'v been having with my gtst but can't find anyone with the same issue. Its completely standard, no exhaust, no pod etc.Everyone with flat spots seemed to develop after mods were added.
I have two flat spots when on boost. Between 4000rpm - 4500rpm & 5000rpm - 5100rpm. It feels like the car is hesitating when it hits these spots and mostly noticeable at full throttle.
Reading the forums I can see its common to have a flat spot between 4000rpm - 4500rpm when you upgrade parts on standard ECU but in my case the car is standard. Before I bought it however I believe it had an exhaust, fmic and pod. The previous owner removed these, serviced and replaced timing belt.
What I have done so far:
Cleaned the AFM
Reset the ECU (disconnect battery/brake pedal)
Replaced plugs
I am running shell vpower. My guess is timing but I don't have the tools/knowledge to check this. I have put around 600km on it since I bought it. Its running sweet besides the flat spot issue. If anyone can point me in the right direction that would be great.
Thanks
Ed
Depends what you call a flat spot. There is normally a dip on the RB25 as the VCT changes over. Did you gap the plugs down to 0.8mm? Give the coils a good clean? Put your location up on your profile so maybe somebody close by can take a drive to compare or point you to a good RB workshop if there is really a major fault.
Thanks KiwiRS4T.
Just updated my location. Have not checked the gap on the plugs yet. Will check it out this weekend. How should I go about cleaning the coils?
Not sure how to describe the flat spot. It feels like the car is holding back from its full potential just after it gets on boost, then boosts hard, then slight flat spot again. Its not as evident on half throttle. Happens in 1st, 2nd & 3rd. Have not had the opportunity to test out 4th or 5th.
Edited by donnaile
What boost is it running? I get the impression its stockish now but had some parts on it that have since been removed. If its running any more than 7 psi then you may run into issues with R&R
Keep in mind the stock gauge is in mmHg not PSI
May not be relevant but there was no mention of a boost figure so thought i would throw that in there.
The other suggestions so far are probably on the money if boost is indeed stock
Its worth a shot free and my r33 developed the same symptoms as that and it was the o2
Sometimes floor it nothing othertimes it goes ok but power isnt smooth or linear
Got a few basic mods but still a r33s2 there getting old 97 model going on almost 20years old
  • 4 weeks later...
I am too having this issue since upgrading my turbo last week ( yet to be tuned), I opened it up on the freeway the other day, all was going well until i got a pop of air from the engine bay and lost boost, all pipes have been checked and only found one lose which did not fix the problem. I have been told the intake manifold gaskets are known for giving in and have been recommended to replace the gasket with silicon??
I had a very similar problem just after rebuilding my engine and turns out it was the TPS not set properly.
If you only use the first inch or so of your throttle does the problem still persist?
With mine i was able to use about a inch or so of throttle and it was like i was using full throttle but anything past that inch or so it would feel underpowered and completely drop boost for a second around that 5k rpm..
You will need a multimeter to set the TPS but its pretty easy once you find a manual off google on how to set it..
Its abit fidly but i used a small screw driver to tap the sencor once i backed off the screws a quarter turn
No so, I can gradualy accelerate and its fine all the way up so long as its not under complete pressure. When i apply full throttle it is fine until boost starts to come on at around 4.5-5+rpm it just seems to almost starve it self self all the way up witch is were i littler cannot take it to.
As i mentioned before in my previous post when it first occurred it did seem like something popped, what it is and were it was is a mystery for the moment, but the noise that occurred defiantly contributed to the problem.
Edited by Antek
Have you checked your piping from the turbo to airbox etc.. i know they can make a popping sound under pressure or even slipt into 2 from crappy clamps done up to tight..
Edit.. also could be a turbo exhaust wheel.. happened to a mates rx7 and he said it made a popping sound.. when he replaced it there was only 2/3rds of the turbine barely holding on
Edited by donburtron
I have, though i will do a through check tomorrow, I did find one lose pipe.. I replaced the clamp.
What do you mean by "slipping into 2"
By splitting into 2 i mean splitting in half and if your on boost at the time it can make a pretty load pop when it lets go..
right-o well.. cheers for the input fellas once again, I been out in the shed looking over all the pipe work on the induction side, yet they came across tight as i wiggled every one of the with some decent force though, it wasn't until i came across a section that was tucked away were i noticed a seep of oil that seemed to spread it self.. long story, lose clamp..
Awesome.. has it fixed the problem?
Yet to be tuned with an upgraded turbo, but opened it up on freeway.
Nah i cant see any problem there
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
