Hi,
so now im trying to make my dream car come true
and i want something super fast lets say 400-450 HP this is all on RB25DET
so up until now i have these parts not yet installed
1- Greedy style manifold + 80mm Throtel body + Fuel Rail
2- Aftermarket Turbo 50 in size
3- NGK Iridium BCPR6
4- RB25DET Gear Box
5- r32 diff + Cusco adjustable Toe control rods +aftermarket full adj suspension
6- Blue pin OEM ECU (r33)
7- 3" Intercooler + HKS SSQV Blowoff
8- Tomi Fuel regulaitor + Oil Catch can + Comtic Headgasket 1.3 - 87mm Bor + AEM 320L PH Fuel pump + Oil dumper
9 - Apexi SFAC 2 + innovate Wideband + Turbo boost controler digital
so what i would like to know what am i missing, what are the things that i purched wrong and it will not have any effect
ah and 1 more thing does the nismo gauge cluster spedo 300 fits the cefiro a 31 ???
i appreciate all the help before i blow my Engine ^_^
Thanks again
Loy
https://www.sau.com.au/forums/topic/463148-rb25det-best-performance/
If money is tight sell the following to buy things you really need:
Greddy style manifold, 80mm throttle body, fuel rail, unknown turbo, OEM ecu, Tomei fuel regulator and all of 9
What you need as a minimum:
Link G4 computer + mac valve for boost control OR PFC + Z32 AFM and boost controller
Decent turbo with (if necessary) wastegate mounted on stock manifold.
Assuming you are running on petrol some 550 side mount injectors
3in turbo back exhaust
Probably a set of new OEM or Splitfire coils.
Good intercooler (you don't say what kind you have)
Good tune
  • Like 1
NOS... two of the big ones.
But seriously, your tune must be good. Try an aftermarket ECU
Thanks Mate im trying as hard as i can to get good numbers
You are missing.
Decent turbo
Proper engine management.
I guess so
You need a decent throttel body...
But yeah, Turbo, ECU, Exhaust.
Maybe E85 if it's available?
It's hard to find one here :(
Link G4 is really costly + no good tuners around
​any brand recommendation ?
Yep Nismo 555cc
can i stick with 2.5" (to keep it quit as possible)
I'm trying to get those
aw sorry the intercooler is Apexi
Good tune
Hard to find one around
  • Like 1
Got more details on the Turbo 50?
I hope this will help
  • Intake Inlet/ Outlet: 4.000"/ 2.625"
  • Compressor:
  • Trim: 60
  • A/R: .70
  • Inducer: 60.30
  • Exducer: 78.00
    Turbine:
  • Trim: 64
  • A/R: .50
  • Inducer: 67.00
  • Exducer: 58.80
ok guys after a few days of searching i couldn't come up with a clear answer for this
i wanted to upgrade my engine injectors so i found some good names
like 550cc nismo - 750 denso - 650 bosh aside for that
what is the right one to chose for my application i mean to have a sweet 400+ without risking
oh and i've changed my ECU and i bought Link G4+ (GTRLink) ....
I have a S2 RB25DET. It makes +-340hp on 0.9bar and just over 400hp on 1.2-1.3 bar boost. Supporting mods are the following:
Garrett GT3071R 0.82AR mounted on stock manifold with external Tial 38mm wastegate
76mm exhaust with 2 Magnaflow silencers
600 x 300 x 76 Autobahn 88 intercooler
1000cc DW sidefeed fuel injectors fed by a Walbro fuel pump, stock FPR
Stock intake manifold with front-facing standard throttle body
Greddy Type RZ blow-off valve
Mishimoto R33 radiator, Nismo thermostat and SPAL electric fan
Rear head oil drain, winged and baffled sump
Link G4 Xtreme management
AEM water & methanol injection
I forgot to add that it makes full boost by 3100rpm in 4th and 5th, about 3800rpm in 1st gear.
Edited by Skylinefreak1
Thats a cool setup but again 1000cc ....
i just bought the 550cc from nismo and i will try to hit this number and i hope i can
for the turbo money is tight to buy one of those Garrett GT3071R monsters any other brands recommendations ?
i will not replace the intake manifold hmmm lets see what will happen
but anyway thanks mate
Get 800cc power enterprise dropin injectors.
Adaptronic plug in Ecu would make tuning alot easier. It supports 3 bar map sensor so no AFM
ATR43SAT Ceramic Ball bearing Rb Bolton turbo. That makes 20psi by 3550RPM 4th, maxed at 424rwhp internally gated on P98 fuel.
Ok, this is the important bit, or you won't make my power:
4 inches induction pipe
PWR 600x300x81mm cooler
3.5 inches turbo back exhaust.
a Good tune
a Good tune
Price on atr43sat cbb if u don't mind telling?
Power Enterprise injectors are absolute junk Tao!
At that rate you might as well get Five O junk too lol.
Better off with Nismo 740cc injectors and be naughty and set the base pressure at 3.5 bar.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
