Hi,
so now im trying to make my dream car come true
and i want something super fast lets say 400-450 HP this is all on RB25DET
so up until now i have these parts not yet installed
1- Greedy style manifold + 80mm Throtel body + Fuel Rail
2- Aftermarket Turbo 50 in size
3- NGK Iridium BCPR6
4- RB25DET Gear Box
5- r32 diff + Cusco adjustable Toe control rods +aftermarket full adj suspension
6- Blue pin OEM ECU (r33)
7- 3" Intercooler + HKS SSQV Blowoff
8- Tomi Fuel regulaitor + Oil Catch can + Comtic Headgasket 1.3 - 87mm Bor + AEM 320L PH Fuel pump + Oil dumper
9 - Apexi SFAC 2 + innovate Wideband + Turbo boost controler digital
so what i would like to know what am i missing, what are the things that i purched wrong and it will not have any effect
ah and 1 more thing does the nismo gauge cluster spedo 300 fits the cefiro a 31 ???
i appreciate all the help before i blow my Engine ^_^
Thanks again
Loy
https://www.sau.com.au/forums/topic/463148-rb25det-best-performance/
If money is tight sell the following to buy things you really need:
Greddy style manifold, 80mm throttle body, fuel rail, unknown turbo, OEM ecu, Tomei fuel regulator and all of 9
What you need as a minimum:
Link G4 computer + mac valve for boost control OR PFC + Z32 AFM and boost controller
Decent turbo with (if necessary) wastegate mounted on stock manifold.
Assuming you are running on petrol some 550 side mount injectors
3in turbo back exhaust
Probably a set of new OEM or Splitfire coils.
Good intercooler (you don't say what kind you have)
Good tune
  • Like 1
NOS... two of the big ones.
But seriously, your tune must be good. Try an aftermarket ECU
Thanks Mate im trying as hard as i can to get good numbers
You are missing.
Decent turbo
Proper engine management.
I guess so
You need a decent throttel body...
But yeah, Turbo, ECU, Exhaust.
Maybe E85 if it's available?
It's hard to find one here :(
Link G4 is really costly + no good tuners around
​any brand recommendation ?
Yep Nismo 555cc
can i stick with 2.5" (to keep it quit as possible)
I'm trying to get those
aw sorry the intercooler is Apexi
Good tune
Hard to find one around
  • Like 1
Got more details on the Turbo 50?
I hope this will help
  • Intake Inlet/ Outlet: 4.000"/ 2.625"
  • Compressor:
  • Trim: 60
  • A/R: .70
  • Inducer: 60.30
  • Exducer: 78.00
    Turbine:
  • Trim: 64
  • A/R: .50
  • Inducer: 67.00
  • Exducer: 58.80
ok guys after a few days of searching i couldn't come up with a clear answer for this
i wanted to upgrade my engine injectors so i found some good names
like 550cc nismo - 750 denso - 650 bosh aside for that
what is the right one to chose for my application i mean to have a sweet 400+ without risking
oh and i've changed my ECU and i bought Link G4+ (GTRLink) ....
I have a S2 RB25DET. It makes +-340hp on 0.9bar and just over 400hp on 1.2-1.3 bar boost. Supporting mods are the following:
Garrett GT3071R 0.82AR mounted on stock manifold with external Tial 38mm wastegate
76mm exhaust with 2 Magnaflow silencers
600 x 300 x 76 Autobahn 88 intercooler
1000cc DW sidefeed fuel injectors fed by a Walbro fuel pump, stock FPR
Stock intake manifold with front-facing standard throttle body
Greddy Type RZ blow-off valve
Mishimoto R33 radiator, Nismo thermostat and SPAL electric fan
Rear head oil drain, winged and baffled sump
Link G4 Xtreme management
AEM water & methanol injection
I forgot to add that it makes full boost by 3100rpm in 4th and 5th, about 3800rpm in 1st gear.
Edited by Skylinefreak1
Thats a cool setup but again 1000cc ....
i just bought the 550cc from nismo and i will try to hit this number and i hope i can
for the turbo money is tight to buy one of those Garrett GT3071R monsters any other brands recommendations ?
i will not replace the intake manifold hmmm lets see what will happen
but anyway thanks mate
Get 800cc power enterprise dropin injectors.
Adaptronic plug in Ecu would make tuning alot easier. It supports 3 bar map sensor so no AFM
ATR43SAT Ceramic Ball bearing Rb Bolton turbo. That makes 20psi by 3550RPM 4th, maxed at 424rwhp internally gated on P98 fuel.
Ok, this is the important bit, or you won't make my power:
4 inches induction pipe
PWR 600x300x81mm cooler
3.5 inches turbo back exhaust.
a Good tune
a Good tune
Price on atr43sat cbb if u don't mind telling?
Power Enterprise injectors are absolute junk Tao!
At that rate you might as well get Five O junk too lol.
Better off with Nismo 740cc injectors and be naughty and set the base pressure at 3.5 bar.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
