Hey guys,
I have a 93 Nissan R32 Gtr that has started having problems with misfires and dropping a cylinder.
I have figured out the problem is coming from the Igniter/PTU (22020-05u00) which I think has suffered from old age/heating issues, started acting up a couple of months ago
I am after advice for how I should proceed from here, should I just replace this PTU with a brand new unit from nissan, etc. (~$650) or go with a setup that avoid this aka Okada Projects coil packs or any other alternatives you may know of?
Additional mods on ignition
Currently have Yellow Jackets Coilpacks and new coilpack wiring harness and 680cc Bosch Injectors.
Running Blackbox N61 Ecu
Thank you for any info you can offer.
Running a Blackbox?
Unigroup customer?
If so, give Yavuz a call and ask about the Morristech 6 channel ignitor. It replaces the standard one. It fixed my spark issues and have no had an issue since.
Thanks for your reply and suggestion.
Was able to speak to Yavuz and recommended the morristech ignitor and going to with that and get the splitfire coils under his recommendation.
Hopefully all works out well :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
