It really depends on your goal but I prefer smaller diameter runners, 6-2-1 with less merge area to keep the gas speed up. This may restrict your top end capabilities a little, but most don't need 800+kw of flow anyway.
Don't forget, the wastegate path is just as important as the turbo, the incorrect angle off the merge may see you struggling to control boost without a 60mm gate, and perhaps limit your top end flow unnecessarily.
Thanks for your input scotty.
Yes the wastegates will be angled correctly, even more so than most of the setups that tends to be at 90 degrees and are for sale these days.
Would love some manifold fabricators/vendors to chime in.
This the guy who made mine - have a look through his gallery:
http://www.sincocustoms.co.nz/gallery/Custom%20Fabrication/2
I had a look, none of those are 6-2 to the flange.
And sorry to trouble you scotty, do you have any photos of your 6-2-1 top mount setups?
Are you making you're own manifold, Mike?
Yes, definitely slow and steady though...
What I wanted to be able to do is have a compact billet collector, makes it as cheap as possible. But also so that you can build a 3-1 tube merge and weld it straight on.
This is my collector effort so far... the T4 flange part is billet machined to get the transition from circle to rectangle spot on.
Good stuff! That T4 flange part is exactly what I wanted as well as a T6 variant.
The 3-1 section off the back half of the cylinders for me would be further away so just a schedule 10 2.5 inch crossing over with the wastegate off that.
The front 3-1 section would be roughly the same or slightly lower with the wastegates being about 60 degrees from vertical, as the power steering/AC will be relocated elsewhere.
Edited by s2d4
why not merge them earlier to create more merge points for extra venturi effects and group each two that will fire close together? above collective looks alot like the usual twin scroll ..
Edited by AngryRB
The merge earlier part is exactly what I said 1 post above yours.
Not sure what you are on about for the "extra venturi effects and group each two that will fire close together" part though.
I can get the flanges made with what ever primary size going into it and a T6 one too... send me a PM.
A more progressive merge and a waste gate port that is more in line with the merge instead of 90° is a lot better but I want to keep it compact and I am using twin 44mm gates so boost control should be ok.
I was on about merging 1+5, 3+6 and 2+4 so you have 3 merge points then they merge into the final collector, when cyl1 fires then number 5 that fires next will have a vacuum in its runner ( venturi effect)
Each merge ( 3 pairs + 1 final merge) would step up in pipe size to encourage flow , maybe start off with a small diameter pipe and get larger at each collector like a set of TRI-Y extractors on a V8
http://www.ifs.tohoku.ac.jp/edge/library/020609ppsn(kanazaki).pdf
Edited by AngryRB
Not sure how that would work for a twin scroll setup?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
