Here is my current map. I am running stock turbos, HKS intakes, decat, HKS Hipower, and power fc. I had boost set to 1.0 kg cm^2 but I didn't reach it because the duty cycle wasn't set high enough. I hit .90. I now have it at 1.1 and lowered some timings and I also added AEM's water methanol kit with the 500cc nozzle. I will soon be doing a 3rd gear pull with my 35% methanol and 65% water mix. If anyone has suggestions they are greatly appreciated even if it's get your ass to a real tuner, haha!
Thanks!
-Dave
Edited by dave5678
https://www.sau.com.au/forums/topic/463200-current-r32-gtr-self-mapping/
Should output it to virtual dyno and work out where max torque is. Then once you're able to determine where max torque is you can started ramping the timing up towards the top.
Because you're running water/meth with those timing figures, you'll fine :)
Hard to purely say from timing numbers without a few dyno runs to determine the finer detail.
  • Like 1
Thanks Johnny! I will be sure to do it tonight with some new logs with meth spraying. Planned on checking out the Wangan/Tatsumi Parking area as well as getting some pictures. Should be good times.
From my experience, say if a car takes x amount of timing on 98RON - on E85 or similar water/meth that particular load point at y rpm will take 4~5 degrees more timing and make more power and torque.
But very hard to say in your situation without a dyno.
I usually start with a flat timing map then add timing till I start to see less power gains throughout the RPM range, then I determine where max torque is achieved and where it starts to heavily decay. This is where timing can be added (from where the torque decays) and then same thing, see if the motor will take timing at that point onwards.
Usually if 1x degree of extra timing makes less than 5kW of power it's pretty much a sign to stop adding timing.
Take whatever I say as only information, every motor, every fuel combination, every tuner etc.. is different. Also a good way to preserve motors is to run it richer at peak torque. The cars I tune (mostly for friends) run about 11.5 AFR at peak torque then lean up to about 12afr all the way to redline (that's E85 converted to Gasoline scaling).
Appreciate the advice. When I get some money saved up I will go to the local turner down the street that has the dyno. He mostly does rotaries but all the Silvia and GTR guys have been going there as well and aren't complaining. Like to do what I can on my own until then even though I know I need to take it there.
I find that RBs don't like too much timing and generally "flat" because of the torque output of the motor is quite "flat" (a good thing).
For example (rpm vs. timing) on 98:
4000 - 20
4400 - 20
4800 - 20
5200 - 21
5600 - 21
6000 - 22
6400 - 22
6800 - 23
and so on...
however on E85 or water meth you can throw a few more up top to give it a more of a ramp
4000 - 23
4400 - 23
4800 - 23
5200 - 24
5600 - 24
6000 - 25
6400 - 26
6800 - 28
(those are arbitrary numbers I've made up, please don't use them)
hehe I won't. Also I'm an idiot and didn't have laptop charging so no logs in copilot or fcedit. I did do one lap on the c1 and used a gallon of meth.
Edited by dave5678
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
