Here is my current map. I am running stock turbos, HKS intakes, decat, HKS Hipower, and power fc. I had boost set to 1.0 kg cm^2 but I didn't reach it because the duty cycle wasn't set high enough. I hit .90. I now have it at 1.1 and lowered some timings and I also added AEM's water methanol kit with the 500cc nozzle. I will soon be doing a 3rd gear pull with my 35% methanol and 65% water mix. If anyone has suggestions they are greatly appreciated even if it's get your ass to a real tuner, haha!
Thanks!
-Dave
Edited by dave5678
https://www.sau.com.au/forums/topic/463200-current-r32-gtr-self-mapping/
Should output it to virtual dyno and work out where max torque is. Then once you're able to determine where max torque is you can started ramping the timing up towards the top.
Because you're running water/meth with those timing figures, you'll fine :)
Hard to purely say from timing numbers without a few dyno runs to determine the finer detail.
  • Like 1
Thanks Johnny! I will be sure to do it tonight with some new logs with meth spraying. Planned on checking out the Wangan/Tatsumi Parking area as well as getting some pictures. Should be good times.
From my experience, say if a car takes x amount of timing on 98RON - on E85 or similar water/meth that particular load point at y rpm will take 4~5 degrees more timing and make more power and torque.
But very hard to say in your situation without a dyno.
I usually start with a flat timing map then add timing till I start to see less power gains throughout the RPM range, then I determine where max torque is achieved and where it starts to heavily decay. This is where timing can be added (from where the torque decays) and then same thing, see if the motor will take timing at that point onwards.
Usually if 1x degree of extra timing makes less than 5kW of power it's pretty much a sign to stop adding timing.
Take whatever I say as only information, every motor, every fuel combination, every tuner etc.. is different. Also a good way to preserve motors is to run it richer at peak torque. The cars I tune (mostly for friends) run about 11.5 AFR at peak torque then lean up to about 12afr all the way to redline (that's E85 converted to Gasoline scaling).
Appreciate the advice. When I get some money saved up I will go to the local turner down the street that has the dyno. He mostly does rotaries but all the Silvia and GTR guys have been going there as well and aren't complaining. Like to do what I can on my own until then even though I know I need to take it there.
I find that RBs don't like too much timing and generally "flat" because of the torque output of the motor is quite "flat" (a good thing).
For example (rpm vs. timing) on 98:
4000 - 20
4400 - 20
4800 - 20
5200 - 21
5600 - 21
6000 - 22
6400 - 22
6800 - 23
and so on...
however on E85 or water meth you can throw a few more up top to give it a more of a ramp
4000 - 23
4400 - 23
4800 - 23
5200 - 24
5600 - 24
6000 - 25
6400 - 26
6800 - 28
(those are arbitrary numbers I've made up, please don't use them)
hehe I won't. Also I'm an idiot and didn't have laptop charging so no logs in copilot or fcedit. I did do one lap on the c1 and used a gallon of meth.
Edited by dave5678
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
