Excuse the possible incorrect descriptions.. I have a 1998 RS4 AWD Stagea (on straight LPG) which is having issues getting the factory petrol gauge to read correctly. I need to find out the factory output range for the petrol tank / gauge for a series 2 Stagea like mine. I know one of you geniuses out there will know this.. My LPG guy said it might be 10 to 85 or something like that.. ?
For those who knew it, it's the car from this post http://www.sau.com.au/forums/topic/226938-lpg-stagea-rs4-series-2
Thanks in advance.
Jason.
umm you would hope the LPG guy would be familiar with how to test the float in the tank to get the answer.
32 GTR is 6ohm Full, 80ohm empty.
I couldn't find the same data in the stagea manual but it is most likely the same.
But frankly, they should take the float out of the tank and test the resistance and full and empty to confirm
  • Like 1
Thanks a tonne Duncan,
I believe that the gas gauge unit on the car when I bought it was a bit dodgy, and with no petrol tank there to test, they didn't know where to start.
As the gas guy looking at it originally was suggesting 10 to 80, it makes sense from your numbers as to why the gauge showed between super full and mostly full.
Cheers!
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
