0/94 R32 GTR
Owned the car since 2006,been in storage the whole time as such its never driven, time for someone else to own and enjoy it, engine has been rebuilt and is fresh so all the hard work is done.
Any and all inspections welcome...
Asking $23,500 negotiable, looking for quick sale
Engine
- Factory long snout R33 GTR engine
- rebuilt bottom end
- ACL Mahle Pistons (have brand new stock pistons still in box)
- Spool rods (have original rods)
- knife edges, grub screwed etc crank
- dynamic balanced
- standard head
- R34 GTR exhaust manifolds
- R34 GTR dump pipes r34/32 02 sensor adapters (have the standard ones)
- nismo exedy ? Single plate clutch & flywheel
- Garret 2860R -9 turbos brand new (have the standard ones)
- Splitfire Coilpacks (have stock)
- 550cc injectors not fitted (have stock)
- nismo Stainless dump pipe (have stock)
- N1 water pump
- N1 oil pump
Interior
- completely stock and original
- seats, carpet and interior condition perfect
- no stereo fitted (wiring has not been cut)
- factory option knee pads
- stardard bubbling on dash
Body
- body is average at best
- paint is in ok condition
- bonnet has hail damage
- front bar is on order from nissan
nismo factory option front strut brace with brake master cylinder stopper
- 17x10 + 12 pittura sport rims
- Pirelli tyres
- original spare tyre is brand new
At worst it needs paint and front bar, or if your chasing power it will need cat back, ecu and tune
cleaned up and registered id be asking over $30,000
but as is im asking $23,500 as is
more than happy to take extra pics if anyone needs
https://www.sau.com.au/forums/topic/463221-1994-bnr32-gtr-gun-metal-low-kms/
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
