I went from NM35 (2.5Lt 250t RS Four) to PNM35 (3.5L N/A 350RX Four).
Theres a power graph on here somewhere here that shows the 3.5 NA vs the 2.5 Turbo. The 3.5 has more top and bottom end, the 2.5T has more midrange.
Yep. Both behave differently, but at stock levels there isn't a ton of difference in straight line performance.
Of course, once intake, HFC and exhaust mods are on the 250t is obviously quicker and the powerband changes but the 3.5 is certainly no slouch.
What I do find interesting is that the whilst the 3.5 is much, much, much more useful putting around under 3000rpm (it really wakes up north of 3500-4000rpm - adding 370z/V36/G37 headers really help build the revs), my 250t was outputting more torque at 3000rpm than my 350rx does.
Performance aside, there is nothing that was inferior on the series 2. Overall, the series 2 is a much nicer car to drive and to own. Also, performance upgrades are incredibly easy to acquire if you are that way inclined.
Of course, if you are referring to going from the VQ25det NM35 to the VQ25dd engine in an M35... you will be disappointed.
https://www.sau.com.au/forums/topic/463234-nm35-to-m35/#findComment-7690426
lolz Cam!!!!......good stock NM35's with the VQ25det have been know to run low 14's with no mod's whatsoever!!! Never seen a stock PM35 get close to that out of the box....14.8/9 was the number I think for PM's...and by no means do they feel as strong up top as the NM35's. HP is about the same in the peaks....its the torque that push's the NM35's along a little better all the way to about 5,800rpm's...no need to rev em after that when stock.....unlike the PM35!
However the guy above is right in terms of refinement....the PM35 is imo a much better all round car in stock form. It comes around to whether you want to mod or not. If you do then the NM35 is the better choice as the end result is much greater as there "are" more choices in setups for any particular person now.....maybe not in the past....but Def now and moving forward.
https://www.sau.com.au/forums/topic/463234-nm35-to-m35/#findComment-7691060
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
