  • Replies 42
The rb20/26 inlet cam gears bolt on the same a the exhaust ones (4 bolts) but the rb25 has one large hollow banjo style bolt that holds the vct gear on.
So without modding the center of the cam aswell as the front bearing surface the stock vct gear wont fit so you need the rb20/26 pully.
John
  ace_nz said:
surely if you put gtr cams onto hydrolic buckets your seat to seat timing would be increased to the point that idle quality will suffer, unless you plan on letting the buckets pump up and running a lash setting that match the gtr cams,  18 thou or something like that.
Not actually correct as the hydraulic follower allows clearance, due to the timing of the oil inlet, but let's just say it doesn't....
Then you end up with 18/1000 extra lift, this is not a bad thing :rofl:
And you end up with longer duration, again this is not a bad thing :D
I really can't see a problem, an RB is not a an old style engine with the hydraulic lifter at the opposite end of a push rod. :D
Just interested in discussing a recent incident with an RB20 that fitted GTR cams. The owner believes some of the inlet valves were staying open off lobe. So would the problem be:
1. The hydraulic follower is pumping too far open
2. the extra lift is pushing the follower too far into the guide and making it stick(the engine is 180K old), I think unlikely. it would stay well open.
3. the off lobe diameter of the cam is a larger diameter than the stocker and the hydraulic follower is jammed at one clearance and won't close to accomodate.
4. bent valves due to timing belt slipping a few teeth as the inlet cam was apperently very tight in the journal.
There were signs of at least one set of valves touched the piston so the timing would have been out slightly, but at least 3 sets stay slightly open. I'm yet to see the head but very keen to follow up and see if they ar all bent valves or one of the other problem I mentioned.
  • 3 weeks later...
  • 3 months later...
  Steve-SST said:
We are doing this conversion but modifying the inlet cam to run the VVT. May be crap but costing nothing to find out so will let you know.
This is on GTSt VSPECs GTS that has 450rwhp on the Stock cams so should be an interesting test.
Has these been done yet??
Any results available?
I have 3 sets of GTR cams and would like to put 1 set in my RB25det if it is worth while.
Save your energy guys, this swap does NOT work.......GTR cams are designed with ramps suitable for .015"-.018" clearance with solid lifters. Put them in a hydraulic lifter engine (RB20-25) with .000" clearance, and you now have longer duration, but ultra-low lift for a fair portion of that duration! Result = bad idle vacumn, crap power, etc, etc.
With that said, I do have 2 sets of GTR cams for sale...$200 per pair, so if you still want to try this swap, knock yourself out. :kick:
B.
Which is why it works for Sydneykid, and the suggestion that it wouldn't work due to ramp angles was laughed at by one of the Northsides' (Melb) better engine machining and building shops.
So you will of course provide dyno charts to support this advice? Make it quick as I'll be limited to occasional whoring from Thailand from 12 tomorrow.
I'm more than happy to concede to concrete evidence that it won't work, but there is evidence to the contrary.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
