Hi,
I'm gonna replace timing belt soon, was told to do water pump at same time..
For a skyline r34gtt rb25det
I found on ebay a set costs around 230 bucks for the lot..
Timing belt
Tensioners
Water pump
Will this be ok for a stock daily driver car?
Here is a link.. http://pages.ebay.com/link/?nav=item.view&id=251865054660&alt=web
If this is not recommended can someone advise a better set on ebay..
Thankyou guys
Edit: the link provided says the pump is not compatible with my car but another listing is..
But in general these are not fake crap are they?
Edited by ifixedit
Golebys parts - gates belt, tensioner, nsk idler, 2x cam seals, crank seal - $180
Kudos - genuine pump - $160
Ebay - gates 3x ancillary belts - $60?
I contemplated a gates pump as their pressure lines, belts etc are amazing and are used on all big machinery. But after a lot of research it seems aftermarket pumps are a lucky dip. For an extra $100 you could have had a genuine pump that will have no problems.
Have you fitted a kevlar belt before?
If not Google "over tensioned Rb cam belt noises", might save you doing the job twice.
I'd think about seal replacement too. I never touch a seal if it's working OK with no weeping.
The oil pump seal in particular may cause some grief when fitting.
With any of these water pump kits, you have to be positive you're getting the correct pump as far as that 6mm bolt up top goes. The e-bay photo isn't clear enough to see if the pump has the hole slotted.
Yeah beware of RB30 pumps sold as fitting an RB25/26, they will but the top bolt doesn't line up - get one for an RB25/26. And I'm with jiffo, I didn't replace my seal, it was fine and 'if it ain't broke don't fix it'.
Thanks for the replies..
I have found another kit.
Anyone think this seller is ok?
http://pages.ebay.com/link/?nav=item.view&id=220670174377&alt=web
It says all Nissan genuine parts
I see he has an optional greedy part.. Not included...
Edited by ifixedit
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
