So im at a loss on what wrong, time to ask?
Bought an 89 r32 gtst m-type rb20det.
Had it about 2 months now, and slowly been starting to run worse and worse.
Was running well when I got it, been using it as a daily (my other cars are a 260rs stagea and a rb30det patrol) so was after a stockish type car, lower fuel use etc, but lately has been randomly playing silly buggers on me.....
1st time, got in it to go to work at 5am, started it up and only 3 or 4 cylinders running?
Took my other car, that arvo I pull the plugs, completely sooted and fouled, put some new bcp6res set to 0.8mm, all good for a while, 2 days later starts missing and coughing, randomly not a solid fault so I assume ignition problem so I Swapped the ignitor for my other cars, problem goes away.
Then a Week later, while on the highway it randomly starts missing again, but goes away?
Happens every so often for a few kms,
Then nothing for a few days, but develops this hectic hunting, like 200rpm up to 1600 back and forth, till it eventually stalls.
So I begin fault finding, changed the fuel filter, no difference, decided to go all out, put my wideband o2 gauge in from my patrol, find its running 10:1 @ idle, so this is my hunting/stall/fouled plug issue,
But!
Anything over 2000 rpm its 17+ afrs.
(Dont know how long its been doing this for?!?!)
Light throttle it has no fuel, I dare not boost it!
So then I think, ah ha! Fuel reg is stuffed, change the reg, install t piece to test pressure,
All good, 43.5 at idle no vac, 36 with vac, take it for a drive and pressure rises with boost but still I have bad afrs?
The hunting problem is fixed,
Afrs are 14-15 at idle, but if I hold rpm at 1500, it drops to 18:1?
So then I checked the fuel pump, thinking its not keeping up with rpm/load,
Pulled it out, put my spare Walbro 255 in, gave it the 12v power mod to eliminate the dropping resistor.
Drove again with the gauge to check pressure, still in spec.
Sooo, then I think well it must be afm related?
Its obviously reading the wrong load.
So swap to a known working afm, same issue, I test the afm wiring back to ecu, found some high resistance on earths, fix it, tests up all good, but still the same issue with lean afrs!
I removed the fuel rail, checked everything is clean, baskets are clean, put it back together, same issue.
So then I put my pfc out of my patrol in, load a stock rb20 tune, start it up, everything is reading correctly......
But same issue!
Here's whats been tested.
-fuel pressure is 100% in spec.
-pressure tested inlet/cooler pipes to 15psi.
-tested for vac leaks on inlet with aerostart.
-tested all earths, to ecu and sensors,
-12v checked at injectors, afm, ignitor, ecu
-no faults at ecu logged.
-tested/swapped afm
-tested/swapped cas
-tested ecu wiring inputs and outputs
Mods list.
-fmic
-3" turboback exhaust
-pod with enclosed box
-rb25det turbo (45v3)
-Walbro 255l intank, wiring mod done,
Stock 10psi boost, gate only.
Stock fuel system, injectors, rail, reg, (except pump)
When I drove it with the pfc, I logged a run to see if I could find probles during playback
Using fc datalogit but nothing out of place via what I saw, except the lean afrs.
PLEASE HELP ME!
Im out of ideas, and getting general unhappy with it!
https://www.sau.com.au/forums/topic/463292-rb20det-afr-issues/
All the way to 8000rpm is 17:1 or higher, it will spike richer if stabbing the throttle but i assume thats due to acceleration enrichment. If i hold any rpm steady (while parked) its just lean.
What ended up being your issue xgtrx?
Ive run out of things to check?
Ive done every test that the workshop manual says, everything checks out as per the book, im out of ideas?
Its running exactly like the injectors are only opening 50% of what they should, like its faulted at an exact value, not intermittent at all if that makes sense?
Mine was the timing fluctuating. Cas issue. intermittent advancement. Thats why I said to check the timing at different rpms cause it costs nothing and easy to do. I have heard of that afm issue also with the pod and modded position.
See how u go.
2x things that come to mind.. especially with our aging old cars.
1. That rubber hose that goes to the aux air control unit, it comes off the cross over/J-pipe.. those tend to break with age
2. PCV playing silly buggers
try blocking both of them and see what is going on.
The iac valve has a new pipe, as i deleted the air regulator when i removed the rail to inspect the injectors,
I tried blocking the pcv pipe but made no difference, i also made sure the valve is checking correctly and free moving.
Have spoken to previous owner (we keep in contact as he owns my old stagea!)
He told me last big service it had, it got timing belt, plugs, splitfire coils (#5 had failed/was failing)
Filters, oils, injectors serviced,
Few other no engine related jobs.
All this was backed up by me actually having a read of the recipts he gave me with it!
Im really at a loss for ideas of what's left to check?
Ok, update, tested every circuit from sensor or actuator bact to the ecu, all continuity checks are spot on excellent condition.
Tested fuel pressure again while driving, all 100% correct.
Pressure tested the whole inlet circuit to 25psi, only leak point was the pvc, so i disconnected it and am running crank case to atmo (for the purpose of fault finding)
The pcv is now fully separate from the engine, check timing is set, tried 15' base and 20' base, proved no different while running.
so it has zero intake leaks, Injector bases started to leak air Slightly at 30psi.
All electrical is 100%, ecu code is 55 no malfunction.
Fuel pressure is 100% in spec.
Still idles at 10:1 off scale rich, afrs are all over the place while driving?
Wtf its got me stumped?
It has now got my old injectors from my rb25de (engine was the head donor for my 30det) still running the same?
I seriously cant fault anything, ive even started again from scratch thinking i probably missed something.
But have come up empty, i even dud all the process flow chart checks from the wshop manual.
Im about to buy a 25 and harness to drop in and just replace this pos!
Id read heaps of threads on 20 issues, and thought id never own 1 cos there obviously no good.
But decided id give this one the benefit of doubt cos i liked the car.
So here i am with 1 and it has issues!
What do ya know!
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
