Hopefully going in next week for a few hrs with dvs-jez, hopefully he can work it put.
Im at a complete loss on what to do?
Ive been right over it, methodically tested and inspected everything from scratch.
No results thus far, still running like a 2bob watch.
Spoke to a few tuners, decided a fresh set of eyes is next on the to do list.
If I cant get this engine to run as it should, then im not going to waste any more time or money on it, seeing its nothing special anyways, (especially after driving my rb26 or 30det, the 20 is very average) ill drop either an rb25det in or neo 25det in it, then develop from there.
So I think I may have fixed it?
Between both sets of injectors, my old set from my 25de and the set out of it, ive found 3 dead injectors in total.
So I measured them all for impedance, basket cleanliness, and set them up and ran them with the old cas spin method to trick the ecu into cycling them, 2 would do nothing and 1 would only work 50% of the time, and 2 of the 3 had high resistance,
So I picked 6 that tested up and functioned ok.
Put them in and it started and idled perfect straight away.
Set the base idle and then base timing to 20',
Took for a drive and feels like stock standard again, happy days!
Afrs are not as tidy as id expect for a factory tune, but good enough to drive properly.
They're atleast steady, close to what id target and not crazy rich/lean like it was.
  • Like 1
Good to see you got it sorted man! Time for a nistune and a mild tune to get the rest of it running perfect ?
Running issues are intermittently happening still.
So.....
Changed out my fuel rail, reg and injectors from my rb30det (hardware i know works) along with the power fc, loaded an rb20det tune along with all the injector corrections to suit.
Drove around all good, drove it work for night shift (27km trip) and it was perfect, afrs where imo spot on the money, drove really nice, crispy performance.
Then drove home at around 2am, nice cool air about 22' and got about 2 min up the road, solid off scale rich, coughing and sputtering its so rich, all the way home.
So i think, only hardware left is the harness, the rest i know works perfectly in my other car, so i strip the harness looking for a short in the injector signal wires
(thinking they're being held open via a ground short circuit, rub through wire)
And i found nothing but a surprisingly good cond harness.
Fml!
Separately wrapped up the inj signal wires, tapped the harness back up, no change obviously!
So put all the stock hardware back in.
Still rich af at idle, (it stalls/fouls plugs if left idling to long)
Ran a new afm harness back to the ecu today, along with different afm.
Ill test drive tomorrow.
Thing has me stumped......
Also to mention, i monitored the map watch and afm voltage at cruise speed,
On flat road, afm voltage and load points where solid and holding steady but afrs where rich off scale 10:1 to 13:1 back and forth while holding steady a load point.
This led me to the short in the harness theory, but to no avail.
So.....
Fml!
As much as I love the rb20dets maybe it's time to just pull the old girl out and source another one or even upgrade to a 25 while your at it? Gotta remember these motors are getting old now a days and could just be old age that's gotten to the inside maybe ?
So.....
Fml!
Im already getting quotes from a few places, trying to get a halfcut to upgrade the box as well.
Possibly a neo with r33 gb combo i think would work well.
ive completely lost faith in this engine, have even spoke to a few rb tuners, they agree to just upgrade it.
    • Even with no BOV you will have issues unless the MAF is a hot film type like the R35 which has some design features to deal with reversion. Hot wire MAFs are very sensitive.
    • So i just change the (whatever is inside ma original MAF and slide the R34 MAF (it is gonna fit right in? ) and somewhere on the hot side a BoV...i presume that would be vented to the atmo? I just "trying" to understand...maybe my mechanic would know this   I would not mind(even prefer) to run stock BoV cuz it is way more than fine but i do not have that and only pipeing what is left is oem J pipe ... I will be running Blitz fmic(to fit oem one side style) and i gonna need custom pipes cuz i do not have rest of those pipes and hoses... But i am want standalone ECU. Only choice i have atm is Nistune...but that is not gonna cut it right?I dont know what Nistune can and cant do... I know you guys know Link and Haltech...but whatabout ECUmaster? I know guys in here run those but i literally do not know about that and do not know differences... Just know to take whatever "my" tuner can work on.
    • Is that the blue one rpm?
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
