I have both turbos. The t04z on 25psi in an rb25 and and -5 on an rb26 28psi. Both standard head and cams. The -5 are more useable in 2 gear and it feels it has more torque from 4500-7000rpm. But the z from 5000rpm is alto more aggressive. I can't comment on gtrs but even getting the -5 set up properly on the gtr is abit of a pain.
Old Z with a newer style billet compressor with a bit of cleaning up comes on 300 or so earlier. Pretty much what a GTW does, yet people always claim more response, like 500 rpm, yet to see it though.
you talking about the 11 blade gtx style t04z wheel that every man and his dog is throwing into 3582's?
cheers
darren
cheers
darren
That's the one.66mm I think. Mate with a Barra has one with a bigger flapper and making 350 on 14 pounds. Response is nothing to get excited about for a 35, will see how it behaves with a valve spring change and more boost.
Dual Ball Bearing Garrett To4Z . 700-750HP flow potential.
Compressor wheel diameter is 84mm exd. / 66.7mm ind. (63trim) Compressor housing is .70 A/R has a 4" inlet and 2.5" outlet slip on connection.
T4 Turbine housing divided A/R .84 entry, all with standard 3" V-band discharge.
Turbine
-Wheel: 74.2mm w/ 76 trim
-T4 Divided Housing A/R .84
Compressor
-Wheel: 84.0mm exd./66.7mm ind w/ 63 trim
-Housing: 0.70 A/R
(707160-5) dash 5's stack up nicely against that compressor map maxing out at virtually the same numbers.
Lower half of the -5 Map looks better as it moves more air at a given pressure which helps with response but tapers off a bit earlier. 28b0d4b57b9b71c0e351d4118c7acc08.jpg
Edited by mr skidz
Don't know mate, I just went for a drive in a few, liked it, bolted one up and thrash the fk out of it and drive it daily.
I am sure there are better set ups out there but I love the power delivery and the fact I drive around under boost all day in traffic and am just a gear change away from shits and giggles.
Once this one goes I might bolt up an old Borg Warner s300 -66, apparently they're good value with similar characteristics.
  • Like 1
70% vs 65% efficiency at the top end makes some difference.
It actually looks like it's better down low as well. Look at the 1.5 pressure ratio and 20lb/min for the z vs 10lb/min for the twins.
*Regarding the to4z map if that's what it is. it seems a bit hard to read but it looks like it says 65% efficiency at the top island of the compressor map, which also requires more pressure to get there.
Just doesn't seem as energy efficient is all I was saying.
but not bad it actually looks really good for an old school single, I like em.
*regarding the 10lb's/min -5 vs T04z 20lb's/min which is essentially 7psi boost and neither have cracked the wastegate at that pressure and they are both identical as the dash 5's are used as twins so it's 10lbs of air from each -5 totaling 20lbs/min.
Look at the popular wastegate pressure ratio of 2bar which is (1bar boost)
it shows the -5's out flowing the T04z by 10lbs/min.
I have had the pleasure of going in a fully built stroked ca18 180sx imported from Japan which had one on it and it was mega still one of the loudest n quickest cars I'd been in.
Edited by mr skidz
Have a look at the 70lb/min vs the 35lb/min.
At the 20lb/min to10lb/m vs 10lb/min to 5lb/min mark, there's definitely more "area" on the z.
Running 1 bar on either of turbos is a waste of time really.
Edited by s2d4
Your doubling the the potential lbs/min flow of the -5 Map aren't you?
So when I see 35lbs it's theoretically 70lbs.
Was just pointing out similarities in flow vs pressure ratios.
Edited by mr skidz
In theory, then in practise it's not when you've got two turbos pushing against each other and twin restrictions on the motor.
Like I said, for those flow values to be anywhere near true in practise you'll need twin cooler, twin plenum to fully separate everything.
question is a little off topic, GTRS bolt up on sr20's reason im asking is I have a set I want to sell :P to the sr20 guys
GTR'S are old, they will make 500kw but to do it right cost more than going single and your not getting anywhere near as a good result!
Off topic but the HKS T04Z is a good looking turbo even now. Far better than my ugly little EFR.
Yes. But I will wait for someone to say "oh they are old tech" without even quantifying (or perhaps understanding) what that means.
it is though... but it's solid tech that works better than any modern tech that runs in pairs.
I don't think this turbo in twin form will perform well on any engine unless upwards of 3500cc as you are not able to cheat and run more boost to make the claimed 850-900 hp because it runs out of compressor at 2bar boost. On a 2.6 with let's say big cams revving to 8500rpm the -5 should make the same power as them at around 1.8 bar. A single turbo on the other hand like a t04z, gtx4088 or even gt4294r I think you are able to cheat because if you don't have massive cams or oversize valves to improve the Ve of the engine( which are essential to make the gtrs work well in an rb26/28/30) you can just run more boost to make the power.
Yeh.its a little turbine driving a big comp wheel.\
My mate has a 3582 on a vl in a 1.06 housing with that wheel. Makes 450rwkw through a loose converter on 30psi. Ran over 140mph.\
But his gate is plumbed back into restrictive 3 inch exhaust aswell.
On 30psi it made no more boost..unplugged gate and went straight to 40psi and maxed fuel pumps out coming on
Another has gone 145mph on 30-32psi with gates vented to atmo with that turbo
The comp wheels a decent thing..needs a gt37 turbine ot similiar. Peformanz turbos in perth selll a turbo with that comp wheel in a 3582 core and gt37 turbine..
cheers
darren
Edited by jet_r31
  • Like 1
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
