Mind blown... Just went to the bottle-o and they had 6packs of beer in 135ml, 250ml, 375ml and 500ml. The small packs looked like they are for children. I'll get photos next time I go there.
In the interests of keeping the topic more organised I'll wait til I'm home before uploading more as photos are spread across 3 devices
  • Like 1
  • 3 weeks later...
1 hour ago, r33cruiser said:
Mate, awesome pic's it looked like an awesome trip.
We're planning to head over next year for 3-4 weeks. How did you find the language barrier?
depends where you are going... when i first moved there i only spoke the basics and being in a town of under 10,000 most things were in japanese and i fumbled my way through it. in the cities most things are in english too. As said below they do speak a bit of english and they do thrive on being complimented on it. some ppl are shy and pretend they cant speak english too. nowadays i speak and read enough to get by with most things
tl:dr
youll have no problems, they are friendly and will help you out
  • Like 1
the walk trail from the end of the suspension bridge up to a small shrine on top of the mountain
34397652941_a652fcfee1_k.jpgIMG_4330 by trev g, on Flickr
34527741585_7b3e8de27e_k.jpgIMG_4328 by trev g, on Flickr
Halfway up Ebino Plateau at a carpark with a view
34398095851_9940c60d10_k.jpgIMG_3356 by trev g, on Flickr
33717663943_76f73290b4_k.jpgIMG_3357 by trev g, on Flickr
33717658703_49c73f688f_k.jpgIMG_3358 by trev g, on Flickr
34486837866_ab51eaaf52_k.jpgP1010046 by trev g, on Flickr
34486862346_2f5178e3a9_k.jpgP1010045 by trev g, on Flickr
Ebino Plateau - We werent aloud to walk in the direction of the hills shown in the first pic due to the amount of gas venting out so had walked towards peaks in the opposite direction. The forest was very eerie...i kept expecting to stumble across a dead body
34142548190_01fd697a88_k.jpgIMG_3371 by trev g, on Flickr
34142543980_c001cc17d3_k.jpgIMG_3396 by trev g, on Flickr
34142537860_f5e0567f72_k.jpgIMG_3397 by trev g, on Flickr
34528116135_6ec909a1a7_k.jpgIMG_3398 by trev g, on Flickr
34528113625_a5eac73ded_k.jpgIMG_3402 by trev g, on Flickr
34486821576_8c67f95c8f_k.jpgP1010051 by trev g, on Flickr
33685241694_2bc058a020_k.jpgP1010052 by trev g, on Flickr
33685225954_07b2873b9e_k.jpgP1010054 by trev g, on Flickr
34486775396_c6ff44e457_k.jpgP1010056 by trev g, on Flickr
34486768186_a96e2eb07a_k.jpgP1010061 by trev g, on Flickr
33685179044_6c8992b9ab_k.jpgP1010063 by trev g, on Flickr
34142412730_866da62153_k.jpgP1010070 by trev g, on Flickr
34528008005_6b3df356b0_k.jpgP1010071 by trev g, on Flickr
33685151114_58fe1a6902_k.jpgP1010072 by trev g, on Flickr
34367214422_19578aa1d4_k.jpgP1010073 by trev g, on Flickr
33685123274_c05c86a342_k.jpgP1010074 by trev g, on Flickr
34142339700_d685082f3c_k.jpgP1010075 by trev g, on Flickr
34367183162_a4d84edeb7_k.jpgP1010076 by trev g, on Flickr
34527935585_1414018290_k.jpgP1010079 by trev g, on Flickr
33685059934_d2899183f9_k.jpgP1010081 by trev g, on Flickr
34402265111_f1e7e84b68_k.jpgIMG_3426 by trev g, on Flickr
34532360765_b6c71dc43c_k.jpgIMG_3428 by trev g, on Flickr
34146725820_0ebe898160_k.jpgIMG_3430 by trev g, on Flickr
33721747523_86d977aa30_k.jpgIMG_3431 by trev g, on Flickr
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
