Saitama and Tokyo the very next day after visiting the skytree from previous post. The snow closed the airports, highways and above ground train lines for 2 days or so
  • Like 1
Naha City/ Okinawa
catching the "super ferry" to Zamami Island to go visit friends who operate a diving charter. got to go out fishing too! This place is absolute paradise!
  • Like 1
Did you get any car parts ? [emoji13] And are the fishing stuff expensive ? Like Daiwa ?
all that fishing stuff cost $400. about $1400 locally. guys at work bought half the squid jigs off me for 300 or so. so everything i ended up with cost nearly nothing :yes:
That's a good deal ! I might do the same to my brother lol ! He's working / Representatives for Daiwa ( Asia) , good tips !
Tokyo Disneyland and Disney sea are both good. I have some great photos of both but cant find them at the moment. should be added in the coming days. They are both targeted at the kids but ive enjoyed both a couple times each. The lines can get really long sometimes. Last time when it was cold and snow everywhere we waited 45 for splash mountain and just as we got to the front my young bloke fell asleep. :glare: was a long heavy trip back to the hotel
It's good fun place for family who have kids , I feels like I'm a big kid when I was there hahahahaha , We bought the front line A pass and no time wasted on lines which is advantage :)
Disney Sea is like Venice through the centre part with all the rides around the outside, will be a bit cold when you visit in december
Been told about the weather and I'll make sure to pack my holiday Jumper [emoji6]
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
