Hey gents, have done a little digging into trying to find out about actuators after a member here suggested I fit an R32 Actuator or HKS Adj Actuator to increase my boost slightly (min 10psi to 12psi max).
Was wondering how I could go about making the purchase I.e where I can grab one, how difficult it is to fit etc for the both (have read the HKS might not be so flash at 10psi)
Running stock boost, only modifications I've made so far are an Apexi Power Intake and Splitfire Coils. Starting out small but enjoying myself! Still planning to upgrade to a catback as part of my stage 1 noob mods.
https://www.sau.com.au/forums/topic/463360-noob-advice-for-actuator-r34-gtt/
if you're going to spend HKS money, you could also consider a turbosmart adjustable unit, which are much better quality units with better tension points and come with a set of different sized springs to set the psi, rather than a screw/spring tightener system that the hks and garrett units have
the point of upgrading the actuators on a stock turbo is only if you are running increased boost pressure, it is beneficial to have an adjustable wastegate actuator to be able to deal with the increased exhaust back pressure. this allows you to hold peak boost for a longer period, where the stock actuators which can't maintain the increased boost pressure will taper off at peak boost
upon googling, i found this good tuning guide for a stage 1 upgrade
http://nissanskyline.6te.net/tuning_GTT.htm
all the best
I wouldn't do that on the stock ECU, R34 GT-t have a pretty premature TP Load cut.[/quote
Rule this out then? I'm not even going to entertain the thought of the next stage of mods I.e ecu, injectors, tunes etc.
Just wanted to see if there was a viable way to increase by boost by 2psi
Run 10psi on a cold evening in a R34 GTt and it will hit the TP Load cut.
Rather spending your efforts on a good turbo back, a good intercooler then focus on more boost when you can afford a Nistune or better.
^^^ What Johnny said. There is no 'quick fix' way to magic up power reliably, start with some planning so you can do it once, do it right.
Well there is. If you follow my suggestion you will get the extra couple of psi OP is looking for without spending a cent.
Fair enough. Will it run ok and with safe AFR with no tune?
I cant see why it wouldn't. its just a simple bleed off which is exactly what a manual boost T controller does.
surprised I haven't seen this method posted before.
I did it to my car when it had an RB25DET and it gave it a little more zip with no adverse affects. A mate at work did it to his Stagea and gained a little. Not the same as a massive turbo but it doesn't cost anything.
Are you forgetting that the stock boost of the R34 is 7 PSI. This is just bypassing the 2 stage boost solenoid to run the full 7 PSI from 3000 RPM. He will have the same boost even after doing this mod......unless he drills out the restrictor hole.
Edited by duffmansbrew
only issue with SK's method or a MBC is he will need an aftermarket boost gauge to see how high the boost is.
drop in a known working R32 actuator and eliminate all stock controls and you have a reliable 10-11 psi.
whats the point of raising boost a few psi on stock turbo, last time i drove with stock turbo i wanted to burn the car, big 10kw's is a waste of time, just follow the normal route which is exhaust, boost controller, intercooler, turbo, computer blah blah
raising boost on a stock exhaust is gay. .. sorry
Edited by AngryRB
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
