HI everyone I have a rb25det neo turbo conversion going into my r32 20de. Haven't started it yet. Will the neo injectors bolt straight in as both are top feed. Or are the o.rings different sizes.
And has anyone done this conversion with some feedback
Cheers
Edited by 32skizza
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/
just saying you're going to regret it and then go ask yourself why you wasted so much time and money on slapping a turbo to a RB20DE then paying $1k for a tune and find out it's slower than your neighbour's bottom of the range diesel golf.
  • Like 3
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/#findComment-7692471
Lol stop replying don't wanna hear it. Ain't paying any money all ready have parts apart from few fittings. Already have ecu and tuning myself. It's my daily. not a race car. That's in the shed.
cool man, do the conversion then.
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/#findComment-7692650
if your looking for a cheap rb20 injector, xr6 injectors will work with different o rings and spacers as the xr6 injectors are longer, or you could just cut the plastic section off the top of the injector and it will fit will no spacers as i've trial fitted one stock xr6 injector just to mock up.
note: factory xr6/xr6T injectors are a down grade and smaller than 270cc
http://www.ebay.com.au/itm/6x-New-Genuine-SIEMENS-875cc-80lb-Ford-Falcon-BA-BF-NA-Upgrade-Fuel-Injector-/151321721730?hash=item233b7a3b82
scotty might be able to get them in a better price
http://www.sau.com.au/forums/user/63525-scotty-nm35/
for a det+t id run a normal thickness metal headgasket so that the compression is not changed and still higher than a det
Edited by Dan_J
https://www.sau.com.au/forums/topic/463371-rb20de-plus-t/#findComment-7693128
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
