Looking for a second hand m35 turbo. Purchase or rent for high flowing. Can't afford to have my car off the road for a high flow service.
There are a few floating around Ben; the NSW FB Stagea group wouldn't be a bad spot to post as well.
  • Like 1
https://www.sau.com.au/forums/topic/463387-wtb-m35-turbo/#findComment-7692506
What's the deal with these 'intense' turbos?
I'm just looking for a basic high flow. Keeping the engine stock.
My car has a good SS1 high flow I would be willing to let go for the right price plus your old turbo.
Made by precision turbo in Sydney
https://www.sau.com.au/forums/topic/463387-wtb-m35-turbo/#findComment-7694062
Sounds like you're disappointed with it.
What's the right price? Keeping in mind, it's a second hand turbo.
I am only disappointed as I have now gone a lot further with my car and 230kw is not enough when everything else other then the turbo is good for 300kw+
But for a stock setup it is great with a good increase in performance.
My car is just a toy now, I wants Powaz !
I would probably let it go for $800 with a trade for the old turbo.
The high flow service I have is of very high standard and cost $1200 to be done. It is a steal wheel now so should outlast the car
https://www.sau.com.au/forums/topic/463387-wtb-m35-turbo/#findComment-7694593
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
