Hi - what size fuse is everyone using with the 450lph e85 walbro pump?
I was on stock wiring for a few months (bad I know), R34 gt4 so no variable voltage, but then popped the standard 15A fuse.
Have just rewired with 8 gauge and a relay, ran for about 10 minutes, then blew a 30A fuse.
Any thoughts? Is the pump dead or do I need to go higher in the fuse rating?
https://www.sau.com.au/forums/topic/463388-walbro-blowing-fuses/
I think you've done something wrong.
I have a 25A fuse on my Walbro with basic 12ga wiring (as it's next to the battery) with a 40A relay and never has blown any fuses.
Not to mention at the track it runs 4.5bar of fuel pressure 80% of the time meaning it would draw approximately 17A for long durations.
Sounds like you've got a short somewhere... check inside your fuel tank to see if your chemical heat shrinks and/or crimps have come apart and shorting.
Yes, ok thanks - it didn't sound right to me either.
Looking at the walbro specs I shouldn't be near 30A currently. Forgot to mention that both times it has broken on me, car was running for about 10-15 mins first, OK when cold.
So either have a problem in the tank, or pump is faulty.
You relay is melting internally, seen it many times.
The coil on large relays needs over 12V to hold the contacts in hard, the car is only supplying 8 or 9 volts sometimes.
Hmmm so that's why my 40 Amp Narva really never ticked over with the ecu signal but the OEM one did
20 amp seems a little small seeing they draw 25-30 but the smaller you go the less spring they have, which should fix the issue to some extent.
I posted a solid state relay circuit to feed 14v power to the relay coil recently, but I notice there are relays for sale with the solid state input incorporated into them these days, for this very reason.
People usually use post OEM relay to trigger their relay setup (so relay on relay).. what you need to do is actually take the trigger off your OEM relay ECU to trigger your new relay setup.
I've done this on many cars and no issues. Alternatively a SSR is a better solution but they are pricey and often need heatsinks to work efficiently.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
