Hi - what size fuse is everyone using with the 450lph e85 walbro pump?
I was on stock wiring for a few months (bad I know), R34 gt4 so no variable voltage, but then popped the standard 15A fuse.
Have just rewired with 8 gauge and a relay, ran for about 10 minutes, then blew a 30A fuse.
Any thoughts? Is the pump dead or do I need to go higher in the fuse rating?
https://www.sau.com.au/forums/topic/463388-walbro-blowing-fuses/
I think you've done something wrong.
I have a 25A fuse on my Walbro with basic 12ga wiring (as it's next to the battery) with a 40A relay and never has blown any fuses.
Not to mention at the track it runs 4.5bar of fuel pressure 80% of the time meaning it would draw approximately 17A for long durations.
Sounds like you've got a short somewhere... check inside your fuel tank to see if your chemical heat shrinks and/or crimps have come apart and shorting.
Yes, ok thanks - it didn't sound right to me either.
Looking at the walbro specs I shouldn't be near 30A currently. Forgot to mention that both times it has broken on me, car was running for about 10-15 mins first, OK when cold.
So either have a problem in the tank, or pump is faulty.
You relay is melting internally, seen it many times.
The coil on large relays needs over 12V to hold the contacts in hard, the car is only supplying 8 or 9 volts sometimes.
Hmmm so that's why my 40 Amp Narva really never ticked over with the ecu signal but the OEM one did
20 amp seems a little small seeing they draw 25-30 but the smaller you go the less spring they have, which should fix the issue to some extent.
I posted a solid state relay circuit to feed 14v power to the relay coil recently, but I notice there are relays for sale with the solid state input incorporated into them these days, for this very reason.
People usually use post OEM relay to trigger their relay setup (so relay on relay).. what you need to do is actually take the trigger off your OEM relay ECU to trigger your new relay setup.
I've done this on many cars and no issues. Alternatively a SSR is a better solution but they are pricey and often need heatsinks to work efficiently.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
