This is awesome! How did nobody here make the connection with March 3rd for an R33 meet?? Time to move to Japan!
Right?!?! Can't believe I didn't think of March 2nd for 32's and that's what I have. Guess I will make it next year!
  • Like 1
Oh hell yes. Any others?
Just 2 more... Next time I will be sure to get more. I am trying to go to Daikokufuto and Tatsumi Parking area more often.
Edited by dave5678
  • Like 1
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
