I do not know if there is any functional advantage to either of the venting arrangements shown above. I modified mine for purely cosmetic reasons as I thought the original R32 engine was a cluttered mess. I put the main vent tubes on the sides of the cam covers, but above the baffle plates. The equalizer tube can be seen below the perforated cover. As for all the bright colors, I prefer something with more of a factory look.
The custom made intake plenum was also done just for appearance, seems to work very well.
I really like what you have done there! Looks very very tidy!
What FFP are you running?
I have no idea what "FFP" is. If you have not seen it, you may want to look at my website, which gives details of the build on the RX-7 and also on the RB20 powered Studebaker. The external spring on the wastegate controller was installed on both cars, and the RX-7 now boosts to 12 - 13 psi. After some tinkering, both cars are now running really well.
stilettoman.info
Edited by stilettoman
stilettoman.info
FFP: Forward facing plenum
R32Pal -
Don't know if you looked at my web site, but the FFP on the RX-7 required about 10 hours work, is shown in this thread in "Forced Induction" post number 24:
http://www.sau.com.au/forums/topic/428716-rb20det-forward-facing-plenum/page-2?hl=%2Bstilettoman#entry6934997
The FFP we built for the Studebaker is much more interesting, required a lot more work of course, shown here in Post number 20:
http://www.sau.com.au/forums/topic/433066-skyline-drivetrain-and-suspension-in-1948-studebaker/page-1
Ben
I have these two photos of the finned rb20 rocker covers, and im assuming that the rear breathers must have been custom done as i cant find any factory rear breathers on these rocker covers.
Does anyone know how why where etc for this setup?
They actually are a custom R31 setup. Not from an RB20.
http://www.jdmautolink.net/2012/02/r31-finned-valve-covers-fits-rb20-25-26.html
The covers originally came off an RB20 though, RB30 are only single cam
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
