Hi all, been a while since iv posted here.
In a nutshell im running a haltech e11v2 piggybacked onto the stock ecu (was to run auto) and basically something is giving noise to the ecu via the temp sensor, it can vary up to 30 degrees cycling as often as every half second or so. This causes big idle problems from shutting off to blowing smoke etc. Iv tried running both the wires separately (not both at the same time) to the ecu and the noise is still there.
Iv not been able to find anything out there with anyone having the same problem. Iv also tried a different sensor. The feed is getting 4.88V and the other is shared ground with the tps. That of which also gives me problems time to time. The noise is only there whilst engine is going and its not relative fluctuations to RPM.
Any pointers would be appreciated! cheers.
Hey mate, have no idea about your exact problem but I do similar work on large mining gear.
Does the feed stay stable when unplugged and engine running? Checking across the pins and also feed to ground, are there any fluctuations. With it unplugged does the ecu show a fault or just a random number (ie -30)
Does it fault at all temps or only cold/hot?
Thanks for the reply,
the feed is stable with ignition but not whilst engine is running. Hot and cold doesnt matter basically the same thing. Only its worse under 70 degrees because its fluctuating cold start curcuit.
I cant disconnect it as its resistance based, if I unplug it it goes to -60 or something, which instantly kills the engine. Im going to try earth the sensor to battery but not sure if that will work.
Id kick off the alternator belt next incase it's done a diode and has a slightly erratic voltage output. And double check ecu voltage for stability.
Have you done any recent welding on the car?
Probe the TPS to see if it is doing bullshit to the voltage on the common earth?
I have swapped the alternator to one with half the kms, and no welding for a long time before this began. It literally happened after being parked for 5 days.
I have run wires directly from ecu to sensor to no resolve. Im thinking of going straight from the ground on the sensor to the negative terminal on battery to rule out poor earth feed?
An GTSBoy, the tps is also brand new haha originally it was my only issue. Itd just lose the zero setting and try to idle out of the base map
Maybe give main chassis earths a clean too, I'd check from batt neg to sensor neg and see if it's 0v. If so I can't see it hurting earthing out the sensor to check
Yeah iv checked it all, and made a big 35 square cable for engine earth too
Does the problem change with tps disconnected? Same pulsing?
I cant unplug it or it dies lol. needs the reading to go into zero throttle idle map.
Ill have a play later in the week when I get a chance lol
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
