^ Wouldn't mind knowing this also, and was it the same method for the pods at the rear?
FMIC looks great! Did you find you had a lot of FMIC hanging below the bar touching on the splash/under tray or was the fit ok? Also, did you require much of the bar to be 'shaved' to accommodate for the cooler?
  • Like 1
Hey guys! :)
To attach the side skirts and pods i used a few little dabs of sikaflex and/or double sided tape depending on the size of the surface as well as some the supplied screws which JSAI sent me along with the skirts and pods.
In regard to the front mount i didn't really have much of a problem with mounting it as it previously had a turn flow inter cooler installed. I can imagine that you would need to shave maybe 50mm off the front bar to fit it, however the blitz turn flow seems to hug tight to the rad support area as the pipe goes underneath.
As for ground clearance i don't feel this is much of an issue (YET) as i am not overly low, i have retained the stock splash guards and under tray, however they did require some trimming, i took a 7cmx7cm chunk out of the drivers side area to fit it back on correctly but you can't see this until you're under the car.. :P
  • Like 1
Seems to always rain only shortly after a wash!
Skylines are like a crack/meth addiction... the only detox is a free C63 AMG which will never happen LOL
Sorry to take this off topic, but been reading your website. Excellent read, especially for a guy who's learning like myself!
  • Like 1
  • 4 weeks later...
A while back i posted a big upgarage box, well i feel it's time to show you what's inside!
Genuine R34 GTR wing with NISMO Carbon Fibre spoiler blade! I got the wing and the blade for less than the blade brand new which i was very happy about.
Carbon Goodness
Sent it off to get painted by a mate's shop, this took a while as it was a cashie but that was no problem.
Very happy with how it turned out
Keen to get out for a drive on the weekend and get some proper photos!
What's next on the car you may ask!
Brake pads, disks, and lines with fresh fluid is up next, currently the brakes are flogged out and need replacing so I'm just going to do the whole lot at once and while I'm there ill slap in a HICAS lock bar, surely that doesn't need explaining :P
  • Like 3
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
