Car looks amazing man, keep up the good work! :woot:
What size are the RPF1's and tyres if I may ask?
Thanks!! :wub:
the RPF01's are 17x9 +22 all round and i am currently running a 235 45 R17 tyre.
I was running a 235-40-R17 but they needed replacing and had a set of 45 profile tyres on another set of wheels so Im running them for the time being and i kinda like the chunky look of the 45 profile :)
Cheers for stopping by!
  • Like 1
  • 3 months later...
Been pretty slack with updates!
But yes I have been doing a few things!
To start I installed some fog lights to the front of the car, I've had these sitting around for a while and thought it'd look cool.
Firstly i started by rolling up into a mates garage.
And took the bar off
Replaced the white/yellow-ish bulbs with a set of very yellow 3000k bulbs
Test fitting
And wired in a little illuminated switch
And drove it home with them complete!
  • Like 1
Other than that, i've just been driving the car which is awesome.
So last week i went to wakefield.
I was so excited, had to get the cliche track day photo right! :D
Got to borrow my friend's NISMO gloves!
Here's a few pics from the day taken by Full Motion Photography!
Wakefield tip; Take the Nespresso machine, coffee is never good..
Car performed perfectly, not 1 issue all day, beat a GTR and set myself a good baseline time for this car :) After that, went for a drive up to dural to visit some family and had to sneak in a wisemans run.
Love it! <3
  • Like 5
I have always liked red R34s, was actually my first choice before i gave up trying to find one and got my yellow one.
Car looks great, keep up the good work. I am glad to see it hit the track and It looks like you had heaps of fun out there.
Thanks for the kind words :)
Red ones sure are hard to come by, I don't see many of them at all!
Track was/is a lot of fun, keen to get back out there!
  • 4 months later...
Small update! I know I've been quiet, but in reality, not a whole log has changed on the car.
One thing I have changed however is the exhaust system. After becoming sick and tired of the drone I got a fabricator friend to get the car on the hoist and we took a look at the exhaust system to pinpoint things I could do to improve it. After taking it off and seeing a rusted out mid resonator as well as a more or less collapsed rear muffler which had turned into an echo chamber, the exhaust was a "write off". We cut out the resonator and welded another one in which was a cheap bandaid fix for a few months however I eventually bit the bullet and sent an email to jesse streeter in Japan to order my new exhaust, the HKS Silent Hi-Power, a full 3" stainless exhaust which really isn't silent at all, but that's absolutely fine, and it's a huge improvment over the droney mess I had before!
Shiny!
Aside from that, not a whole lot has changed, I'm just washing it regularly and driving it a lot which is a nice change really! Im hoping to get out the the Feb SAU NSW Cruise if anyone would like to say hello :)
  • Like 2
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
