^ Wouldn't mind knowing this also, and was it the same method for the pods at the rear?
FMIC looks great! Did you find you had a lot of FMIC hanging below the bar touching on the splash/under tray or was the fit ok? Also, did you require much of the bar to be 'shaved' to accommodate for the cooler?
  • Like 1
Hey guys! :)
To attach the side skirts and pods i used a few little dabs of sikaflex and/or double sided tape depending on the size of the surface as well as some the supplied screws which JSAI sent me along with the skirts and pods.
In regard to the front mount i didn't really have much of a problem with mounting it as it previously had a turn flow inter cooler installed. I can imagine that you would need to shave maybe 50mm off the front bar to fit it, however the blitz turn flow seems to hug tight to the rad support area as the pipe goes underneath.
As for ground clearance i don't feel this is much of an issue (YET) as i am not overly low, i have retained the stock splash guards and under tray, however they did require some trimming, i took a 7cmx7cm chunk out of the drivers side area to fit it back on correctly but you can't see this until you're under the car.. :P
  • Like 1
Seems to always rain only shortly after a wash!
Skylines are like a crack/meth addiction... the only detox is a free C63 AMG which will never happen LOL
Sorry to take this off topic, but been reading your website. Excellent read, especially for a guy who's learning like myself!
  • Like 1
  • 4 weeks later...
A while back i posted a big upgarage box, well i feel it's time to show you what's inside!
Genuine R34 GTR wing with NISMO Carbon Fibre spoiler blade! I got the wing and the blade for less than the blade brand new which i was very happy about.
Carbon Goodness
Sent it off to get painted by a mate's shop, this took a while as it was a cashie but that was no problem.
Very happy with how it turned out
Keen to get out for a drive on the weekend and get some proper photos!
What's next on the car you may ask!
Brake pads, disks, and lines with fresh fluid is up next, currently the brakes are flogged out and need replacing so I'm just going to do the whole lot at once and while I'm there ill slap in a HICAS lock bar, surely that doesn't need explaining :P
  • Like 3
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
