Nice work with the diff I have been doing the same with mine. If you get time you should also consider changing every bolt to a zinc plate and powder coating the whole subframe. There are a few mods that you can do to the subframe to improve on traction.
Nice thread
  • Like 1
  • 2 months later...
I've been incredibly lazy with updating this and I'm sorry!
I've been up to a few things, like driving the car servicing it and installing my Nismo 1.5 Diff, see below, picture heavy as always!
Along with the diff i installed a new sub frame with fresh bushes and weld in reinforcement plates which makes the rear end feel much more stable.
Started by jacking up the car and dropping this big old slab of fun out of the back..
I then unbolted all of the arms from the subframe, and carried them over to the new one and bolted them on.
I left all the bolts on the hub side done up which saved a bit of time.
From there I filled up the diff with oil
..and bolted up the ABS sensors
aaand finished up by bolting the biff in as well as the shafts
xFbDDQRl.jpg?1
This was the remainder:
I then helped my mate install a turbo back exhaust on his R32. Of course the "bolt on" just-jap was 80mm too long and needed to be cut and shortened but it was a good laugh..
All in all a pretty good day!
  • Like 3
Do you have any more photos of the exhaust, where it needed to be modified ect. I'm more than happy to take this information back to our supplier.
I've done about 700km with it now, there's certainly more sounds and feelings compared to the stock one, but I knew that was coming and I personally don't really care. Once it's warm it feels pretty standard and makes no noises anyway.
It's improved nearly every other aspect of actually driving the car and I love it. I highly recommend it!
I also popped some HSD coilovers in over the weekend. Not an overly difficult job at all. Actually I think that comes down to patience but eh.
I ordered these via @Street to Track who was really helpful! I already had an idea of what I was after, but he was able to answer any questions I had, and I had the coilovers only a fee days after ordering for a great price. I also got a braided clutch line, however didn't install that on the day.
Drove up to the garage, opened up the box and jacked up the front of the car.
For the fronts you're required to clamp a metal braked to the shock body which holds the abs sensor wire. Not too difficult at all.
Once that's on, unbolt your old leaky nismo shock and slide it out of the way, and slip the new one in!
Do the bolts up tight and re-attach the abs sensor bracket to hold the wire out of harms reach. While the car was up I also took the time to move the wheel arch loom a little closer to the body with some extra cable ties and clips.
For the back it's similar enough, I did however undo the rear swaybar as it was making the bolts a bit hard to un-do, but that's 4 bolts away from being on the floor :)
I know they're not the best coil over of all time, but they fit my needs perfectly and didn't cost too much. They're not overly uncomfortable either and it has dramatically increased the handling/feel of the car. Car has some pretty mean rear end grip with the new suspension and 1.5 way :3_grin:
I think nismo S-Tune stuff would have been great out of the box, however mine was fairly thrashed out by this stage with 2/4 shocks leaking and the car feeling very boaty/bouncy
Since then I've ordered a full water hose kit from kudos for the car so the next job is to replace the gktech replacement clutch fan with a new OEM item as my previous was starting to get the famous stress cracks along the hub and replace all of the rubber hoses in the car. While I'm in there i'll also look at buying or making a set of braided turbo lines for peace of mind.
  • 1 month later...
Went to Japan for a little bit, mucked around and checked out tourist side as well as the car side of things there which was great fun.
With that, I also brought myself a host of goodies home which I've been either giving away to friends, or adding to my car. I've so far installed the Nismo GT500 Shift Knob Titanium Version which I bought from Nismo, an endless brake sock this cool LED Flare as my car didn't come with a flare. It's basically a replica with a heap of LED's in the top and runs off a couple of AAA Batteries, pretty neat!
Anyway, so that was fun! But after driving my car for a little while which has been great fun my friend told me my centre brake light had stopped working :( So I ordered an LED replacement from eBay as some what of an experiment and I've added some pics below.
Excuse the somewhat uninteresting photos..
Started by unclipping all of the trip clips
Which leaves you with...
In this case you'll need to remove the whole housing, so unbolt the two big bolts and pull it all out
From there you need to seperate the red lens and the housing which is held in with 2 clips.. Once this is done I plugged in the LED pannel and mounted it in place with the supplied double sided tape, and 2 tiiiiny screws.
I put it all back together as well as put some sound deadening on the boot lid while it was all apart and gave it a test!
It's bright, quite bright actually! But honestly for a brake like I think that's a good thing anyway.. Another little job done!
  • Like 1
  • 2 months later...
I've got a motorkhana / wet pan day coming up this Monday which I'm keen for. I've done a few little service items to get the car in shape for it as you would for any other track day.
I started by getting a wheel alignment, I hadn't gotten a wheel alignment after installing the diff and new subframe, or the coilovers so this was well and truly overdue.
I then took it home for a wash
I also got a water temp gauge as the standard one isn't overly helpful. I'm not a huge fan of aftermarket gauges so I've put it in the glovebox with an alarm set on it. It's out of the way and can still get my attention if needed.
I started by running power and signal wires from the glovebox over to the steering column area where all the other wiring is
Plugged in and mocked up a spot for the gauge
I then put the sensor into an aeroflow temp sensor adapter I bought:
And put the top rad hose back on;
Gave the cooling system a quick bleed, set the alarm and we're done!
Simple peace of mind mod!
  • Like 1
  • 3 months later...
Happy new year!!
Been doing a little bit of work here and there on the car. I've since replaced the radiator with a thicker alloy radiator and while I was in there replaced the GKTech fan with a brand new Nissan item, soooo much quieter.
Picture heavy update below!
Old gear out:
New gear in:
All finished!
Went on a bunch of drives
Signed up for a Motorkahna / Wet Pan day
Which was an absolute blast, highly recommend it! This was an awesome time to really put the Nismo diff and latest suspension bits to the test. The car was a beauty to drive, no issues at all and had no problem both gripping and sliding all day.
Drove it to the track, thrashed it and drove it home.. Can't ask for more than that!
Life was good! Until i went for a quiet drive one rainy night when suddenly I could smell that hot steamy coolant smell. Both stock, and my aftermarket water temp gauges hadn't moved, but I wanted to be sure so I pulled over and good thing I did, a small hose from the inlet manifold to the oil cooler had a pinhole leak and was leaking coolant.
Turned off the car and got a mate to come rescue me with a trailer and put it in the garage.
I think it looks mean without a bumper!
At this stage I'm working through replacing every rubber hose under the intake manifold with genuine Nissan parts which yes is expensive, but really is the best way to go about it. I've got all 14 or so rubber hoses with new metal fittings and stainless clamps for the whole lot. I'm also going to replace everything else that's under there, don't want to go back under the intake unless I really have to.
Check out the difference between a new, and the old hoses!
More updates coming soon!
  • Like 2
Keep the pics coming.  Great to see people enjoying their rides safe and responsible.
Hoses do perish.  Make sure you have reasonably fresh fuel hoses too.  My 33 developed a pinhole in the pressure feed to the rail, about 2 months after it came off the boat.  Could have ended in a flaming mess on the roadside.  On inspection, there was a bulge in that pinhole area and it just gave way.
Thanks mate :)
They sure do! I've got new fuel line and a filter to replace all of the fuel lines in the engine bay while it's all apart.. Cheap and simple maintenance while it's all apart anyway
22 hours ago, mlracing said:
Those hoses are a major pain in the ass to replace but definitely worth doing
Too right mate.
In saying that, it's a good chance to do it once and do it right as well as clean up and paint a few other things that are otherwise a bit of a pain to get to.
  • Like 1
Slowly but surely getting the job done with these hoses, glad I'm in here, there's no way these hoses have been touched since Nissan put them there, all of them are seized up and need to be cut to get off. VERY glad I decided to replace them all in one go, rather than 1 by 1 because another failure was just around the corner.
Replaced with a brand new fitting
All new hoses installed with any bad hose clamps replaced with new stainless ones.
While the car was apart it was a good time for me to give the rocker covers a coat of paint. From the factory, the Neo covers come raw and tend to soak up all sorts of oil/dirt.
Gave them a good wash with degreaser and the pressure washer before masking them up for paint.
Being raw alloy I used some etch primer on them, I used this back on my intercooler piping and had great results.
And to finish them off, hit them with a low gloss/quick dry black.
I then replaced the gaskets with new ones using a "Platinum Gaskets" kit, just from eBay, this came with the gaskets, half moons, bolt seals and an oil cap gasket all for $70, pretty happy with that.
They fit pretty well and seem like a tight fit, I guess time will tell. The good thing is they are blue, if they do leak it will be very visible and I can replace them with OEM items but honestly it's a rocker cover, not an oil pump.. :)
  • Like 1
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
