Have a r34 gtt that's has had a minor front ender
Rest of the car is good
gearbox is epic
engine parts:
coilpacks $20 each
turbo $300
head $350
bottom end $350
wiring loom $100
or make a offer on the wholelot
other parts
Gearbox 1250
Doors 200
window mechanism $80
door cards 70
3 gtt rims with rubber $200
rear bumper $100
boot$100
brakes 350
diff $150
hubs 80 each
fuel tank $100
sold things
Seats 50
Dash 80
Anything you want just ask
Located valley heights Sydney
Pete 0448468884
post-219-0-25259700-1457351247_thumb.jpgpost-219-0-77923100-1457351269_thumb.jpgpost-219-0-08640900-1457351293_thumb.jpg
https://www.sau.com.au/forums/topic/463485-r34-gtt-part-out/
Do you have the gear shift surround?
na sorry everyone wants one of those you have to be quick
Likewise, second dibs, posted to Melbourne? ;)
as above
price on ash tray and hand brake lever with the cable from the cabin through to the underside of the chassis
ash tray 50 bux comes with a centre console
handbreak 100 as i have to pull it out
Pm sent
back at ya
Has the front reo bar been cut?
i dont know what a stock on looks like but it does appear to be cut i will get some better pics and post them up
Do you have airconditioner and mount points for the cdplayer and the DIN surround?
Damien
will check to see if they are there
You wouldn't have the blinker plugs/wiring for the front would you?
yea i do send me a message and we can work something out
pete
Price on dash cluster, passanger window motor, steering wheel (no airbag needed) sent to Melbourne?
Edit: Oh and perhaps the plastic engine cover too please?
Edited by HaydenThaGr8
Edit: Oh and perhaps the plastic engine cover too please?[/quot
Only have the engine cover and steering wheel left of that lot
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
