Hi, I am a newcomer to this forum, It's my first skyline and a first turbocharged car as-well,
Couple weeks ago I purchased 1994 R33 GT-s with some mods, but It has trouble getting to boost.
mods as go:
Forged pistons,
Greddy style Intake,
Top Mount mani
Z32 - Ecu&Maf
FMIC
Blitz Dual SBC - Boost Controller.
HKS External Wastegate?? (Hidden deep under manifold, have to remove some stuff to see what it is) looks like early version of HKS wastegate.
LS Coil Pack
GT3076 Ball Bearing with .60A/R
HKS SSQV valve.
The thing is Boost comes on only after 4-4.5K RPM and it has no transition, after 4k it's instant full boost. I tried playing around with Gain & Set on boost controller, I can adjust the boost to my needs but cannot get boost point to come lower.
As I see, this setup should produce boost much easier, I suspect it could be the wastegate, as I see boost coming on at ~3K gets up to .3-.5 Bar of positive boost than back at 0 and I can hear dumping air sound
Is there any way I could check operation of the wastegate? or If you think there could be any different reason for this behavior
You could remove the gate and use a compressor to test it?
I doubt you will get it on that much earlier with a highmount manifold, but make sure the VCT is operating, that will improve the response a fair bit. z32 needs some mods to control VCT I seem to remember, is it Nistuned?
Yes The ECU is nistuned and at least I was told that VCT is operating correctly. I have not gotten around to see whats what on this car just preparing homework for now.
I might think of installing stockish manifold if it help's with the response but I will probably try to stay with top mount and work on other flaw's like horrible fmic piping and a downpipe with dual 90 degree bends hoping to get at least some more respone and check if everything is wired / hosed correctly, as it feels something is just missed.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
