lol headroom
pull thermostat out let it run at 40 degrees then
good luck
I'll stick with my factory thermostat which is working brilliantly.
At 40 degrees that idiotic, you want it at min. 80 for oi viscosity to be correct.. a R33 thermostat is perfect for this.
Each to their own, no point arguing if you barely understand what I am trying to say.
It's a simple formula: clean and clear radiator (stock or aftermarket), good condition water pump, correct thermostat, properly bled correct coolant in the system.
To find the problem start with the cheapest and easiest item above, check and or replace said item. If that fixes the problem good. If it doesn't fix it then go to the next item. Repeat until the problem is resolved...
Yeah a new rad and thermo is definitely on the list. I think I'll just stick with the standard thermostat.
Also tee'd up to buy an intercooler off of someone on SAU today, will this be beneficial towards this, or worse? If my rad isn't cutting it, I think worse
I understand, my sarcasm indicates I can't be bothered explaining it a second time. For someone so smart I'm surprised you didn't pick up on that.
FMIC reduces radiator efficiency slightly, yes. But not enough to make ANY practical difference if your cooling system is up to scratch.
Fix your cooling system. TBH I wouldn't even be driving it if the temp gauge is going past half way.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
