This weekend I hope to have my Bora to a state where I can actually start it for the first time since October.
The engine is empty at the moment, no oil. But theres a chance a little bit of coolant got in it. So, I thought I'd run a flush through the engine when I'm also flushing my cooling system.
I don't want to spend a bajillion dollars on some super nice, thin, synthetic oil if it is going to be used for 15 mins tops.
Will I do any damage using a cheap shit oil to idle the car for 15 mins?
Also, as the car has not run for so long, should I pull the leads off and turn it over without spark to get oil into the head?
Thanks guys.
Do exactly what you said. Go get a bottle of oil of the right viscosity. I would say use a oil formulated for diesels aswell because they have more cleaning agents in them.
And yes. It would be a good idea to crank it until oil pressure builds up then bobs your uncle.
  • Like 1
because it's a TDi (I assume) can you install a dose pipe and record it going suuuuuuuuuu tututuuuuuuuuu tuuuu for us?
much appreciated :)
Its not a TDI. :(
I have no idea what you're asking. :yes:
needs a dose pipe LOL
in other news, Costco has cheap synthetic oil, great for your application... start/run/dump
Nice. I'm not a member of costco because I'm nowhere near one. :(
Might be worth the trek tho?
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
