Gear Knob, Valve cover, Nismo sticker, Wheel centre cover, Turbotech MBC, Radiator,
Basically nothing too critical. anything important I source locally from a reputable seller with in store warranty.
the radiator was flushed and tested before installation.
the MBC was bought from Turbotech.
A more appropriate question for me would be "What haven't you bought off Ebay" to which my reply would be "Um..... nothing!"
I bloody live on the stupid thing. I think I might have the male version of a womans handbag addiction. And I'm tipping a large number of you other blokes on here are in the same boat!
I'm up to 543 purchases on Ebay now. I tried to tally it up at a few years ago (they've changed it so you can't look it up anymore) and it was well over $10000 worth of stuff. I'd reckon it's maybe close to $20K now.
I think I need to do an online shopping addiction therapy session....
  • Like 1
I buy almost everything from TradeMe (NZ's equivalent to Ebay) as many dependable suppliers use the platform. There is rubbish to avoid as well of course. I buy some stuff from UK Ebay if the price and freight is right. I buy very little from AU Ebay or US Ebay as nearly all the vendors insist on using the most expensive form of freight (and some US vendors won't export!). The exceptions on the US Ebay site are electronics and car parts listed on the US site by Hong Kong suppliers who will send stuff for low or no freight cost.
Shit tons of stuff. I remember 10 years ago, I had to find H4H bulbs for my car, ebay saved the day. Since then Ive bought hundreds of items. Much of it is cheap stuff from china. Hell Im even running taiwanese ebay spec ball joints and they've held up fine going on 4 years now. Electronic components are also considerably cheaper compared to jaycar which has exorbitant markups on small items.
Rb26 genuine greedy manifold for $400.
Gaskets, was missing one, guy didn't give a crap.
2x China gt42 turbos (first may have bearing material in it)
Turbo oil lines
Turbo oil lines for twin turbos
Midori dump pipes(since sold)
Castor arms
Tomei expreme exhaust manifolds (since sold)
Front camber arms
Rear camber arms
Single manifold (yet to be used)
50mm precision wastegate (since sold)
R32 gtr driver seat redone in leather for $150
Intercooler lower hard pipe kit
Hicas lock bar
2000 audi a4 quattro (without inspection.)
Needed a clutch and other items.
I'm sure there's more, just can't think of them atm.
543 purchases, or is that just how many people you have traded with.
Feedback score is only people dealt with iirc.
So, buy 5 items from 1 person, means 1 on tear feedback number.
I bought some violet metallic flake powder for a respray job on my R32. $25 for 25 grams, laid on a black base coat and added the flake to the clear at 5 grams per litre. Sprayed it in a carport with some tarps and it came up okay. Turns plenty of heads and I regularly get a thumb up ( IRL ) and sometimes even a " nice ride bro " out in the world.
Custom Pearl Finishes is the store for anyone looking to do their own respray on a budget.
IMG 017
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
    • From what I understand, the normal Nismo diff is a bit harsh, and the Pro is the one that behaves more nicely, and you only pay Nismo tax twice to get it.
