Hey Folks, looking to get a batch of stickers made with the SAUWA logo. looking for numbers before i proceed so i dont get stuck with too many.
Can either get the logo printed on a clear sheet as previously done or vinyl lettering individually cutout with a sheet over the top holding it together for ease of fitment.
The vinyl option is only a few cents more and the owner said it should last about 7 years before fading whereas the print on clear sticker might fade after 2 years. i'm keen to get the vinyl from his recommendation.
I've priced it up for a quantity of 50 assuming everyone will want 2. they are 200mm wide by 100mm tall.
Pricing would be 2 x stickers and postage for $10. If i can get 10 pairs confirmed im happy to proceed but if i cant secure that many then i will only do a very small order for a couple of us however the price will likely increase.
so who is keen?
https://www.sau.com.au/forums/topic/463559-sauwa-stickers/
Aww just about finished writing and my stupid phone deleted what I was writing when your message came through, all good!
Hey guys, does anyone mind if I increase the size a little?
Originally I said 200 x 100 but there is a little bit of fat left in the $10 I quoted. I'd rather everyone get the biggest sticker possible for the money your paying. Not sure how much bigger, maybe 250 x 120. Just thought I'd check incase anyone had a small side window in mind...
I'll contact the supplier tomorrow and see what they can do for me and hopefully put the order in.
Any problems let me know
Trev
  • Like 1
https://www.sau.com.au/forums/topic/463559-sauwa-stickers/#findComment-7698912
All good - do it!
Trev
https://www.sau.com.au/forums/topic/463559-sauwa-stickers/#findComment-7698922
Dan the Man is busy with some stuff at the moment - don't wait for him he has some important shit on his plate.
Just do what you need to mate,
Im ok with that or if you wana do a 50/50 in the sizes im ok with that too.
  • Like 2
https://www.sau.com.au/forums/topic/463559-sauwa-stickers/#findComment-7698936
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
