2016 Round 4 - Sunday 10th April Hosted By Piarc
acsplit
 Share
940981_1293651613994545_2337888272813527
First time at the Island for 2016!
Sunday 10th of April (Untimed day running on the Saturday)
- For anyone interested in attending their first track day here all you need to know : http://www.sau.com.a...y-requirements/
Licence:
You will need a CAMS to compete on the day.
L2S can be obtained via https://www.cams.com.au/
Other requirements : http://www.sau.com.a...y-requirements/
Phillip Island Grand Prix Circuit
Back Beach Rd, Phillip Island VIC 3922
https://goo.gl/maps/43e4m1BtEWu
Pricing:
Entrants: $225(early bird discount up until 31/3) Price after 31/3 $265.00
Dorian Timing hire $15.00 (required)
Spectators: Free
These days can be a sellout so get your entry in quick.
Entry/Registration
Make sure you put SAU-VIC in the club field of your member profile.
You will also need to choose a class If you are not sure just choose modified.
For this event we are making the CAMS Event Entry available to use as an option, to access this system go to https://www.meecamsau.com/ or the CAMS website and click on the CAMS Event Entry logo.
In this system you will need to create a login and enter your details. Once you have set up your details, you will be able to enter events without the need to fill out entry forms.
There are a couple of information videos on the CAMS Event Entry website that guide you through the process.
Supplementary Regulations can be found here
Squires Loft Nunawading will be putting on lunch for all SAU VIC members (Comment in this thread if you are attending so we can cater accordingly).
To everyone who missed out, it was a perfect day!!!
Lots of time on the track, smoothly run and any incidents were handled quickly.
Weather was perfect for the track, and somehow managed to shave almost 4 seconds off my PB :woot:
  • Like 3
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
