940981_1293651613994545_2337888272813527
First time at the Island for 2016!
Sunday 10th of April (Untimed day running on the Saturday)
- For anyone interested in attending their first track day here all you need to know : http://www.sau.com.a...y-requirements/
Licence:
You will need a CAMS to compete on the day.
L2S can be obtained via https://www.cams.com.au/
Other requirements : http://www.sau.com.a...y-requirements/
Phillip Island Grand Prix Circuit
Back Beach Rd, Phillip Island VIC 3922
https://goo.gl/maps/43e4m1BtEWu
Pricing:
Entrants: $225(early bird discount up until 31/3) Price after 31/3 $265.00
Dorian Timing hire $15.00 (required)
Spectators: Free
These days can be a sellout so get your entry in quick.
Entry/Registration
Make sure you put SAU-VIC in the club field of your member profile.
You will also need to choose a class If you are not sure just choose modified.
For this event we are making the CAMS Event Entry available to use as an option, to access this system go to https://www.meecamsau.com/ or the CAMS website and click on the CAMS Event Entry logo.
In this system you will need to create a login and enter your details. Once you have set up your details, you will be able to enter events without the need to fill out entry forms.
There are a couple of information videos on the CAMS Event Entry website that guide you through the process.
Supplementary Regulations can be found here
Squires Loft Nunawading will be putting on lunch for all SAU VIC members (Comment in this thread if you are attending so we can cater accordingly).
I'll be there in my daily so looking forward to a nice casual day.
Looks like it might take the rest of the year to get the EVO back 'on track' so to speak.
  • Like 1
To everyone who missed out, it was a perfect day!!!
Lots of time on the track, smoothly run and any incidents were handled quickly.
Weather was perfect for the track, and somehow managed to shave almost 4 seconds off my PB :woot:
  • Like 3
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
