I want to do a DIY install for my intercooler on my R33 but would like to get hold of some full install instructions. It is a 600x300075 cooler - same size as the Hybrid ones. Can someone supply me with a scan of the install instructions so I can figure out what/where to cut, what to bolt the cooler onto, where to run the pipes etc?!? It'll make it a lot easier for me.
MearCat
https://www.sau.com.au/forums/topic/46366-intercooler-install-instructions/
MearCat
Mate I did mine recently (4 weeks ago) and I had instructions from Hybrid.
They did not instruct you as to cut what and where. it becomes pretty evident once you get the front bar off. The structural paert of the cutting is easy as you can measure the distance of the bolts after you have put your FMIC on and are replacing that sttructural front piece.
get your gring and start grinding.
The front bar takes a little more mucking around with but the time is worth the wait.
Be patient take your time and the rewards will present them selves.
I can fax you the stuff I have from Hybrid if you want, its for an R33.
PM me as I am at work and I am pretty sure I stiil have them in my car.
Cheers,
J-Flash :)
