Hi guys.
Both items are located in Georges Hall. Shipping will be paid by the buyer as well as paypal fee's (if you want to use them)
Item: OSG "3 speed" gearbox with OSG Billet sandwich plate.
Price: $5,000
Condition: Like new. I picked it up from Award Diff and Gearbox yesterday having just been fully refreshed. It had a 2nd gear failure (one tooth broke off) which was replaced with a brand new gear. It also received a 1st/2nd selector sleeve and a brand new 2nd synchro ring. This box is basically brand new. I kept Nissan standard 5th gear for reduced RPM on the freeway.
Link to gearset. http://www.otomoto.com.au/p/4146449/nissan-skyline-gt-r-and-z32-5-speed-close-ratio-gearset-by-os-giken.html
Link to sandwich plate: http://www.otomoto.com.au/p/8745823/nissan-billet-sandwich-plate-for-skyline-.html
35A4864C-5E3C-41D4-A981-6BC8B8889E5A_zps
BB5F90C3-32C1-45F8-B008-658CD288EE42_zps
84A8CA80-F7BF-4851-95FC-F67AF0CEF663_zps
961D2403-C0C6-4A4C-9BAA-8D48C3D82F8E_zps
6F973B85-49A3-4B77-B283-EC059CAC6014_zps
0F3006A8-7EC3-4748-A926-1D6F9050F2D7_zps
Item: Nismo Coppermix Twin Plate - Competition Model (Pull type 5 speeds only)
Price: $1,200
Condition: Used. It has been in my car since 2005 and has travelled roughly 35-40,000 Kms. Only removed when I went to an OSG OS88 gearbox. It wouldn't fit. This clutch would have to be THE clutch to use on a street driven GTR. They just do not die, lovely to drive and not heavy under the foot.
* I will take friction plate thicknesses tomorrow and post them up.
*Or buy both for $6,000.
Clutch photo's. Both plates wore exactly the same. From what I can gather, new thickness is 8.0 mm and 7.1mm is where they are considered needing new plates. This was holding 472 RWKW on a 2.8 stroker when it got pulled out.
Top plate
D81F0F94-9824-44DA-9166-4788290C2C6B_zps
Bottom plate
5BE11861-3B49-4E7C-896E-BE6FE4B8B46D_zps
Front cover
12B258EC-9627-4793-B913-E944760F8CDD_zps
Back of flywheel
4BD702FB-39AA-4236-BE51-7F3C076909EB_zps
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
