My picks to suit various budgets - it is more important to change every 5000kms / 6mths whichever comes first, more so than a more expensive oil over a longer interval.
Under $30 - Gulf Western Syn-X 3000 10w 40 - solid performing semi-synthetic (refined mineral base) only published figure is the TBN of 9.02 (solid for 10,000km intervals) and good pour and flash points.
Over $40 - from light to heavy 40w oils - Shell Helix Ultra 5w40, Nulon Fast Flow 10W40 and Penrite HPR10 (10w50 extra 10 which is just a strengthened 40 weight) - all use a Group 3 refined mineral base, however they improve on the Gulf Western oil by meeting the synthetic standard of ACEA A3/B3, as well as many euro extended-interval standards such as Mercedes 229, and BMW ll-04.
Over $80 - my pick would be Redline's 10w 40 standard motor oil, which offers IMO the best combo of detergent for street, and high temp/sheer resistance for performance (HTHS of 4.4, compared to the Shell which has a rating of 3.68).
All these oils have a good combo of cleaning detergents / high-temp/sheer performance - IMO the difference in competency isn't alot over a 5,000km/6mth interval of street/spirited driving.
Factor in track time and extended change intervals, and the more you want to consider a higher priced oil like the Nulon, Penrite and Redline.
Edited by squareznboxez
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699233
Penrite 10 tenths racing, Motul 300v or Mobil ultimate allround performance.
Those 3 oils are one of the best out there for turbo charged cars. Viscosity is obviously dependant upon engine mods, driving conditions and weather.
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699334
Agreed these are out and out performance oils, however they are designed to be run on track at high temps with high sheer stability (which is good), and then changed after each event - the result is the detergent package in these hi-performance 'track oriented' oils is usually poor and not ideal for day-in-day-out start/stop accustomed to a street car
the 300V is now specifically a track-oriented oil, with very little detergency for 5,000km/6mth intervals
the Penrite 10 tenths isn't far behind however they should have some street manners - my pick is still the HPR10, but the 10 tenths does have a Group IV PAO basestock, where the HPR10 uses a Group 3 refined mineral base
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699508
I did a little research based on what you said and 100% agree. Motul 300v is track oriented.
To the OP, i stand by the Mobil ultimate all round performance as its one of the best oils out there made for high performance cars. Its more expensive (around 100 dollars for 5litres) but its pretty damn good. To put it in perspective, i have been told a few guys have used this oil in their old ferrari's and its never skipped a beat.
HPR is also pretty decent. My mate is running penrite Everyday fully synthetic in his G6E turbo which is pushing 330rwkw.
You shouldnt really go wrong. Ive tried different oils in my evo ranging from castrol edge, motul 300v, penrite hpr, penrite racing, mobil ultimate all round etc.. and by far mobil was the best for daily driving.
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699770
You're on the money with Mobil 1, based on many UOAs (used oil analysis) in the US, this has proven to be a very, very competent street/track oil
Although they have changed to a refined mineral base but extremely competent additive pack making the overall product possibly better than the previous Group 4 basestock version
The RRP of $105 is a lot of money though, and i think there are better street oils out there like Redline, Amsoil and select Elf.
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699802
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
