Hi, hoping someone can help me.
I'm having some trouble with the harmonic damper on my rb26, the motor is in an unmodified s13 chassis so it is a reasonably tight squeeze. I am running a rb25 ps pump and rb25 ps bracket, so the normal GTR harmonic dampers will not line up (10mm too long). The rb25 (r33) damper is a perfect fit, but as I haven't run a 26 with a 25 damper before I am a little worried, theoretically it is only a damper and the crank is internally balanced so it should work fine. Has anyone had to do this before? The car is solely used for track so it sees big revs consistently. If I run the gtr balancer, pump and bracket it will Run extremely close to the radiator. (not ideal).
I have tried to sort this out with a very reputable workshop in Sydney but Ive found Ive been ripped a new one for parts, the particular employee couldnt even keep up with his own lies and now I am $1000 out of pocket and no harmonic damper.
As you can imagine after being stung badly by a company that is supposedly the rb gurus in Sydney, I find myself questioning any info I've been given. And what's probably an easy fix has me sweating bullets.
Any info on this would be greatly appreciated.
https://www.sau.com.au/forums/topic/463685-harmonic-damper/
As far as I'm aware the main differences between RB balancers is the belt setup. So by that theory using a 25 balancer with 25 ancillaries should be fine. The key ways and everything else will be fine.
https://www.sau.com.au/forums/topic/463685-harmonic-damper/#findComment-7698906
Thanks for the reply, I got onto Ross balancers today and they had no worries with the rb25 balancer on the 26. Going to go for their gold series as it's the best they make for race application. Hopefully the final piece of the puzzle. What was a routine freshen up turned into an 8 week adventure due to 1 incompetent pleb who I really want to name but I am still trying to get my $1000 back. So for the moment the workshop will remain nameless. But a quick search on this forum confirms I'm not the only one.
https://www.sau.com.au/forums/topic/463685-harmonic-damper/#findComment-7699402
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
