I've been searching and can't seem to find any information on
-When/Where do we receive our tickets, buddy passes, gift packs and etc?
-What time do the gates open for entrants?
-What time do the gates open for people who purchased vip entry
-What gate are we using?
have there been any updates on any of this?
Pretty sure I was one of the first to pay and send my form in, but I haven't heard anything yet, or been contacted by anyone to confirm all is received and everything is good.
Not feeling the love :(
Yeah..... Me too!
I'm getting nervous that I'll roll up and they say they haven't received my entry.
Bob.
Damien yes your name is on the list.
If we don't get to everyone individually, please give us some credit that maybe we'd chase up with you at the due date to see what is going on.
I will ensure everyone that posts in this thread has their entry received.
Bob I haven't seen yours yet, when did you send it in? I will get an updated list and let you guys know. (note I'm following up but I don't have the mailbox details)
They hit my credit card on March 31.........$80.00
Cheers,
Bob.
So to be clear, the payment goes to Motive DVD but we're collecting the forms for them which we will submit together so that we can park together as a club.
Did you send your forms to the SAU NSW Gmail account or straight off to Motive? Or is it possible you're in the Heritage display?
Yes I'm Heritage display and I sent the forms directly to them.......
Cheers,
Bob.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
