Up for sale is my daily (to & from work)1996 R33 GTST.
Its time to move on as this was my midlife crisis car (missus hated it..lol) but i still do love it dearly and it will be sad to see it go.
Its a very clean example of this model with no tears in the interior or marks on the duco.
It has the following mods..
Nistune Ecu
Bosch 040 Fuel Pump
HyperGear SSPU1 turbo
550 injectors
Blitz intercooler
Modified standard air box
Ecutalk OBD display
V35 Rims
Blue dash lights
Sub in boot
GTR rear adjustable wing
removed cannon & replaced mufflers to make it look cleaner with HSV exhaust tip
Replaced heater core & re gassed aircon works great
It has Rego until June 2016
looking at $8000 or best offer
Regards,
Darren
Edited by itshimdazza
https://www.sau.com.au/forums/topic/463716-1996-r33-gtst/
  • 4 weeks later...
Hi mate just wondering if the car is still for sale. If so would it be possible for you to put up photos of the interior...( seats etc ) and also a picture of the engine bay....Also how many kilometres has the car done too
many thnx
Johnny
Edited by GTR-32U
https://www.sau.com.au/forums/topic/463716-1996-r33-gtst/#findComment-7712582
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
