I dropped my M35 to JEZ DVS last weekend for EMU setup and tune.
JEZ already finished hard wiring work today and try to tune my car, but he found my car has stall problem:
car starts for 1 second then stalls but not always.
all inputs outputs from EMU looking good. has injector pulse, spark, fuel pressure.
he said it is a fuel issue as they can get it to start with spraying bake cleaner into the inlet manifold replaced the fuel and the engine runs for a few seconds.
currently he let battery be charged and will check cold start tomorrow.
here is my setup:
GCG highflowed turbo
HDI FMIC
Walbro pump with constant 14v
840cc denso injectors
Blitz EBC
KN air filter
scotty dump pipe
2.5" straightly catback with 100cell cat (no budget for 3" currently)
innovate wideband O2 with AF meter
anyone has idea for stall problem?? :woot::woot:
https://www.sau.com.au/forums/topic/463726-greddy-emu-setup-help/
Does it have an alarm?
yes, but you cannot start engine at all without unlock the immobiler. JEZ knows how to use the immobiler.
the problem is engine could start for 1 second then stall, not can't start at all.
Edited by YangLIU
Ignition lock problem?
Did you replace the fuel filter in the tank and in the engine bay?
Jez said injectors can't open when cranking.
I have replaced fuel filter in tank before. When is the other one in engine bay?
186.5rwkw@16psi, 194.6rwkw@19psi
currently using 2.5" catback. i will import my kakimoto 3" catback soon from Japan. also kakimoto 3" de-cat front pipe is in my garage for a while.
So thats who bought that kakimoto decat pipe.... the one on ebay?
yes it should be, it has big canon, LOL, that's why i didn't ship it to AUS so far...
I know someone local in Sydney that may be interested in selling his kakimoto. It's my old exhaust, in great condition.
Let me know if your interested and I can put you in contact
Thanks mate. I already bought kakimoto n1 from yahoo auction since last year and it is sleeping in Japan garage now. Since I have tuned my car and need 3" exhaust, I am trying to ship it back to Sydney these day.
Btw, do you know if there is big difference if I fit kakimoto 3" de-cat front pipe on my car? I am afraid of it is too loud.....
It will be epic loud. I ran a 100cell cat with mine and it was still very loud.
It did sound awesome though. Haha
I think 100cell will not give much help on this. I am afraid of the cop, you know they could easily defect your car with 100 different reason. Lol
I had no cat on my Legalis R when I bought the car.
Fitted a 100 cell cat, couldn't notice any loss in power at all (under 5000 rpm )
Also the cat didn't make it any quieter really. Maybe 3-5 dB
Just want it to be legal, plus bonus bung for tuning.
Still over 110 dB.
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
