How bad is it to do a rev dump burnout in 1st gear? what is the proper way to do it? after rev dumping first gear, are you meant to put it into second while easing off the accelerator or can you flat shift it into second? I sat it on the spot for about 10 seconds in 1st gear and im pushing just under 200kw. Also, is it ok to just straight up rev dump it on second gear? Basically, what is the safest way to sit it on the spot
Not bad at all, we all do them all the time. Its the only way to launch a Skyline or a Silvia. And yeah flat shift is easy as, wait till valve bounce and pop it. Even third if your car is tough enough [c'mon u know it is!!!].
And finally, the safest way to sit it on the spot is to keep doing said burnouts till your clutch shreds. Then it will sit on that spot for as long as you want.......or until tow truck comes anyway.
  • Like 1
I have 461kw + 1000Nm and no burnouts for me, reckon I will have to rev it till the valves bounce and step off, the only thing smoking will be my clutch, lol
Your tyres are too big for your 10 in rims. Stretch some 215s on and instant burnouts (if the tyres stay on that is...)
burnout is when you feel depressed and can't go on..............you were just pushed way too far and now your physically and mentally exhausted............bit like this thread really.
Do this, guaranteed good smoke:
  • Press clutch
  • Slot into 3rd gear (hold it in gear so it won't pop out)
  • Mash the accelerator, make sure it is bouncing off the limiter
  • Depress clutch as fast as you can, the faster the better
100% crowd pleaser, I did this at the SAU NSW Texi
  • Like 1
Don't listen to this guy, this video clearly demonstrates how to do a burnout.
  • Like 3
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
