If interested txt me on 0426296161 k7st txt me for pics
Hi stripping an r33 skyline series 1 just ask for pictures im located in werribee
Rb25det with all bolt ons expect turbo and ecu $1200
Na manual gearbox $500
Headlights $200 pair
3 inch stainless steel cat back exhaust$200
Drivers window reg $50
Passanger window reg $50
Igition barrel and locks $150
Series 1 stock bonnet red $100
Drive shafts $ 100 for the pair
Stock rear bar black $20
Geuine r33 side skirts $120 pair (small crack underneath side skirt)
5 stud front and rear hubs $200 set
Non turbo front cailpers $50 pair
Series 2 spolier $20
Aftermarket strut brace $50
Diff $100
Green label afm $50 each
R33 starter motors $30 each
Stock exhaust $50 each
Series 1 reo $50
Series 2 reo $50
red front guards pair passanger side has small dint $70 for the pair
Stock suspension front rears $100
Rb25det bare block $100
Manual tailshaft $100
manual raditior $50
Auto raditior $50
R33 geuine pods $40 pair ( little damage wont be seen once put on the car )
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
