Re-advertised...
Need to make room in my garage -
1 pair of early Recaros for sale, v/good condition, come with rails (suit JZA70 Supra) $400ono
1 pair stock R33 GTS seats - $150ono
1 anodised blue GFB 'Basic' BOV and alloy R33 GTS adapter - *SOLD*
6 x RB25DET injectors and stock fuel rail - *SOLD*
Not sure what freight would cost to QLD, I can look into it, unless you want to from your end?
I've attached pics of the stock GTS seats above.
I want the old Recaros but I have no idea how much it would cost to ship to Sydney.
How much do rails cost for a pair?
That lawnmower runs 10's Dean.. on nitrous and ELF fuel. It'll cut through steel star pickets too! NOT FOR SALE - sorry :D
cul202,
I'll find out how much freight costs when sending large items from Adelaide to wherever.
To get both Recaro fitted and good to go (they have rails but don't suit an R33/32) into an R33/32 I have been quoted ~$250 to $350.
Bride rails will also suit these seats, but Bride rails cost heaps! I paid ~$250 for one.
Ok, I contacted Aust Post and for two seats it will cost the following:
Adelaide to Sydney - ~$19ea (~$40 pair)
Adelaide to Canberra - ~$24ea (~$50 pair)
Adelaide to Brisbane - ~$30ea (~$60 pair)
Adelaide to Melbourne - ~$18ea (~$36 pair)
Much cheaper than I thought! :D
EDIT: Too cheap in fact - AUST POST WERE WRONG. PRICES ABOVE ARE "NOT" CORRECT. WILL FIND OUT CORRECT FREIGHT COSTS SHORTLY.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
